I would try with the internal oscillator at 16MHz first.
I disabled the MCLR- function on pin 1 since you do NOT have a pull-up resistor there.
Sorry, I use the XC8 compiler.
// PIC16F722A Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FOSC = INTOSCIO // Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF // RE3/MCLR Pin Function Select bit (RE3/MCLR pin function is digital input, MCLR internally tied to VDD)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config BOREN = ON // Brown-out Reset Selection bits (BOR enabled)
#pragma config BORV = 19 // Brown-out Reset Voltage selection bit (Brown-out Reset Voltage (VBOR) set to 1.9 V nominal)
#pragma config PLLEN = ON // INTOSC PLL Enable bit (INTOSC Frequency is 16MHz (32x))
// CONFIG2
#pragma config VCAPEN = DIS // Voltage Regulator Capacitor Enable bits (All VCAP pin functions are disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of for ON and OFF.
<xc.h>
Then try with an external oscillator (max 20MHz) to pin 9.
// CONFIG1
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN)
// CONFIG2
<xc.h>
