Author Topic: pic 18f4620 pwm (enhanced) half bridge mode  (Read 3390 times)
Offline spidermanIIIITopic starter
  • Country: eg
« on: March 02, 2016, 09:50:59 pm »
hi, i want to make pwm and its complementary for half bridge so i choose pic 18f4620 but it give me one pwm but the complementary doesn't appear i read the datasheet he datasheet
what is the problem please help me
//names
//var
//modules
 void init_(){
              trisc.b2=0;
              portc.b2=0;
              trisd=0;
              portd=0;
              CCP1CON=0b10001100; //enable half bridge
              TMR2=0;
              PR2=124;      //for 500 Hz
              CCPR1L=20;
              T2CKPS1_bit=1;     //prescalar 16
              T2CKPS0_bit=0;    //prescalar 16
              TMR2ON_bit=1;    //timer 2 on
             }//init_
void main() {
             //setup
             init_();
            } //main
Offline sarepairman2
Re: pic 18f4620 pwm (enhanced) half bridge mode
« Reply #1 on: March 03, 2016, 05:03:39 am »
http://www.linear.com/product/LTC6992-1 2$
http://www.ti.com/lit/ds/symlink/sn74lvc1g04.pdf  0.5$
lack of compiler errors ? priceless
for everything you don't want to get grey hair from, there's analog.
« Last Edit: March 03, 2016, 05:10:41 am by sarepairman2 »
Offline Howardlong
« Reply #2 on: March 03, 2016, 07:00:18 am »
I don't have an 18f4620 but I do have an 18f4550 which also has the ECCP and looks, from the DS, to be an identical peripheral. I breadboarded it up and your code works (although I re-wrote it to use the standard Microchip XC8 peripheral definitions). It generates contra-signals on P1A and P1B as expected.
I note that some silicon revisions of your chip have a reasonably extensive errata including with the ECCP, I don't know if that affects your revision.
// PIC18F4550 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1L
#pragma config PLLDIV = 1       // PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1       // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = INTOSC_HS // Oscillator Selection bits (Internal oscillator, HS oscillator used by USB (INTHS))
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON         // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3         // Brown-out Reset Voltage bits (Minimum setting 2.05V)
#pragma config VREGEN = OFF     // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON      // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config ICPRT = OFF      // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
void main(void)
    TRISA=0;
    TRISB=0;
    TRISC=0;
    TRISD=0;
    TMR2=0;
    CCPR1L=20;
    T2CONbits.T2CKPS1=1;     //prescalar 16
    T2CONbits.T2CKPS0=0;    //prescalar 16
    T2CONbits.TMR2ON=1;    //timer 2 on
    while (1)
        NOP();
    return;
  • Country: eg
« Reply #3 on: March 03, 2016, 08:03:14 pm »
first of all I wanna thank you for your help. can you please attach the hex file i need and can you explain what you mean by I note that some silicon revisions of your chip have a reasonably extensive errata including with the ECCP, I don't know if that affects your revision.
Offline oilburner
« Reply #4 on: March 04, 2016, 02:31:27 pm »
Thanks for the giggle, I love this post!
Offline Howardlong
« Reply #5 on: March 04, 2016, 04:25:23 pm »
You need to check your chip's errata. As for giving you a hex file for a chip I don't have, I'd rather not, debugging in the blind isn't a speciality of mine! Why can you not take the source code I've offered?
