Author Topic: All variables should be Global  (Read 19848 times)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: All variables should be Global
« Reply #75 on: March 04, 2017, 01:01:17 pm »
Here's an optimization you probably won't get from the compiler: read it as an array.
Compilers use pointer arithmetic all the time. They're not made as dumb as you think.
They can even re-order non volatile statements to fit the arithmetic.
Online brucehoult
« Reply #76 on: March 04, 2017, 01:12:21 pm »
I've never seen a compiler take a series of hand-written statements, identical except for the literals, and extract the literals into an array and use a loop. And I write compiler optimizations for a living :-)
You *could* do it. It's just the inverse of unrolling, which compilers do all the time. But it would be quite expensive to find, and would only very seldom find code on which it could do it. And then you just made the program slower, so it's only something you'd do when optimising for size, which is also not the common case.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #77 on: March 04, 2017, 02:09:28 pm »
I was looking in some 8051 listing. Code fetches a pointer to a global.
Next 5 different globals are accessed by adding to the pointer.
It doesn't put them in a loop, but it skips the pointer fetch.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #78 on: March 04, 2017, 03:25:37 pm »
It's quite standard to use pointer + offset to refer to a stack frame, for example.  That's easy to set up, though: the variables are allocated in specific locations, they can be used independently -- and the offset can be called out independently, thanks to instructions like MOV reg,[reg+imm].
It's not obvious that a compiler would know how to resolve that into an array access: one where the pointer itself is moving.  That would complicate other stack accesses, at the very least: if you use one MOV reg,[reg++] instruction, now all subsequent offsets have to be one less, and so on.  If it's inside a loop, the offsets vary from time to time, and you can't make that assumption at all.  Then you need to use a new pointer register (which is available on many platforms, at least).
I don't know that compilers will ever create a loop to optimize for size; speed is the most common optimization after all, and it's nice that unrolling a loop is a much more well-defined problem than rolling one up is!
Bruce seems to have confirmed my suspicion, so at least I'm not completely wrong for once. :)
Seven Transistor Labs, LLC
