Author Topic: Can all ARM7s have their contents downloaded with jtag?  (Read 1756 times)
Offline rigrunnerTopic starter
« on: February 03, 2015, 11:37:05 pm »
Hello everyone,
I'm used to having to grab rom data from proms of one type or another, so this is a new area for me.
I've got a device here with an AT91R40008 on it which i'd like to take a look at the rom data. It doesn't have any obvious jtag interface so i'll need to pick up any necessary connections from the chip.
Is it a straight forward task to hook up a jtag to this and down/upload with it or are there different tricks and tips for each chip depending on its circuit?
Internet of Things: A solution desperately trying to find its problem
Offline andersm
Re: Can all ARM7s have their contents downloaded with jtag?
« Reply #1 on: February 04, 2015, 12:28:09 am »
Unless I'm terribly mistaken, the AT91R40008 is romless, so just desolder the external rom and read them out with your prommer. As a general rule, any chip with internal rom will have security mechanisms to prevent reading out the contents via debug/programming interfaces.
« Reply #2 on: February 04, 2015, 12:50:56 am »
Thanks for the info.
An external rom should make it much easier :)
