Author Topic: HC-05 PCM AT commands  (Read 2663 times)
Online ali_asadzadehTopic starter
« on: October 17, 2016, 10:01:24 am »
Hi
Can We use the PCM in HC-05 module for sending and receiving audio PCM data? what are the AT commands for them,I could not find any info about that in the module datasheet
Also it has used a CC2580 chip, Do we have a datasheet for it?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline linux-works
    • netstuff
Re: HC-05 PCM AT commands
« Reply #1 on: October 19, 2016, 02:55:12 pm »
that's the serial i/o chip, right?
if so, it is not meant for anything other than serial low-speed i/o.
I've heard you can reflash it and get access to lower layers but that's real hacker territory.
for audio, you really want an apt-x enabled codec pair or the audio will sound about the same as fm radio or cassettes (ie, garbage by today's standards).
« Reply #2 on: October 19, 2016, 05:11:42 pm »
I want something with Audio capability and USART at the same time, do you know or recommend something absolute cheap?
