I want to learn to program a LCD and I am doing a tutorial.
-How can I understand this code below?
-what is the main structure to understand for a LCD?
;* Microchip Technology Inc. 2007 *
;* Assembler version: x.x *
;* Filename: *
;* lcd.asm (main routine) *
;* Dependents: *
;* Main.asm *
;* Modified Jan 2013 *
;* PICDEM Explorer DEMO code. *
#ifdef __18F8722
list p=18F8722
#include p18F8722.inc
#endif
#ifdef __18F87J11
list p=18F87J11
#include p18F87J11.inc
#endif
#define LCD_E temp_reg, 6 ; LCD E clock
#define LCD_RS temp_reg, 7 ; LCD register select line
#define LCD_CS LATA,2 ; LCD chip select
#define LCD_CS_TRIS TRISA,2 ; LCD chip select
#define LCD_RST LATF,6 ; LCD chip select
#define LCD_RST_TRIS TRISF,6 ; LCD chip select
D_LCD_DATA UDATA_ACS
delay res 1
temp_wr res 1
temp_rd res 1
Dreg1 res 1
Dreg2 res 1
temp_reg res 1
GLOBAL temp_wr
PROG1 CODE
;LCD Initialization routine
global LCDInit
LCDInit
bcf LCD_CS_TRIS
bsf LCD_CS
clrf temp_reg
call Delay
call Delay
call Delay
bcf LCD_RST_TRIS
bcf LCD_RST
call Delay
bsf LCD_RST
call InitSPI
call InitPortA_SPI
call InitPortB_SPI
bcf LCD_E
bcf LCD_RS
call WritePortA
;Function Set
call Delay
movlw b'00111100' ;0011NFxx
movwf temp_wr
call InitWrite
call Delay
movlw b'00001100' ;Display off
movwf temp_wr
call InitWrite
call Delay
movlw b'00000001' ;Display Clear
movwf temp_wr
call InitWrite
call Delay
movlw b'00000110' ;Entry mode
movwf temp_wr
call InitWrite
return
;Function to write to the PORT
InitWrite
bcf LCD_E
bcf LCD_RS
call WritePortA
call WritePortB
nop
nop
nop
bsf LCD_E
call WritePortA
nop
nop
nop
nop
nop
nop
nop
nop
nop
bcf LCD_E
call WritePortA
return
;LCD busy delay
global LCDBusy
LCDBusy
call SDelay
call SDelay
return
global ClearLCD
ClearLCD
movlw 0x01
movwf temp_wr
rcall i_write
return
;Write to Line1
global LCDLine_1
LCDLine_1
movlw 0x80
movwf temp_wr
rcall i_write
return
;Write to Line2
global LCDLine_2
LCDLine_2
movlw 0xC0
movwf temp_wr
rcall i_write
return
;Write data
global d_write
d_write
rcall LCDBusy
bcf LCD_E
bsf LCD_RS
call WritePortA
call WritePortB
nop
nop
nop
nop
bsf LCD_E
call WritePortA
nop
nop
nop
nop
nop
nop
bcf LCD_E
bcf LCD_RS
call WritePortA
movf temp_wr,w
movwf TXREG ;carriage return
btfss TXSTA,TRMT ;wait for data TX
bra $-2
return
;Write instrution
global i_write
i_write
bcf LCD_E
bcf LCD_RS
call WritePortA
rcall LCDBusy
call WritePortB
nop
nop
nop
nop
bsf LCD_E
call WritePortA
nop
nop
nop
nop
nop
nop
bcf LCD_E
bcf LCD_RS
call WritePortA
return
;Initialize MCP923S17 Port
InitPortA_SPI
bcf LCD_CS
movlw 0x40
movwf SSPBUF
call Check
movlw 0x00
movwf SSPBUF
call Check
movlw 0x00
movwf SSPBUF
call Check
bsf LCD_CS
return
InitPortB_SPI
bcf LCD_CS
movlw 0x40
movwf SSPBUF
call Check
movlw 0x01
movwf SSPBUF
call Check
movlw 0x00
movwf SSPBUF
call Check
bsf LCD_CS
return
;Initialize SPI
global InitSPI
InitSPI
bcf TRISC,5
bcf TRISC,3
movlw 0x22
movwf SSP1CON1
bsf SSP1STAT,CKE
bcf PIR1,SSPIF
return
global Check
Check
btfss PIR1,SSPIF
goto $-2
bcf PIR1,SSPIF
movf SSPBUF,w
return
;Write to MCP923S17 Port
WritePortB
bcf LCD_CS
movlw 0x40
movwf SSPBUF
call Check
movlw 0x13
movwf SSPBUF
call Check
movf temp_wr,w
; movlw 0xFF
movwf SSPBUF
call Check
bsf LCD_CS
return
WritePortA
bcf LCD_CS
movlw 0x40
movwf SSPBUF
call Check
movlw 0x12
movwf SSPBUF
call Check
; movlw 0x80
; movlw 0x40
; movlw 0xc0
movf temp_reg,w
movwf SSPBUF
call Check
bsf LCD_CS
return
GLOBAL Delay
Delay
nop
nop
nop
nop
decfsz Dreg1
goto Delay
decfsz Dreg2
goto Delay
return
SDelay
decfsz Dreg1
goto SDelay
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
decfsz Dreg1
goto $-2
return
goto $
END
