Resistor + low power zener + 100nF cap should do the job.
Take the lowest nominal current zener you can get, ex. SZBZX84C3V3LT3G seems pretty stable at 100uA, so the resistor should be adjusted to ensure 100uA at lowest voltage (8-3.3V), ex. 39K:
8V = 120uA
12V = 223uA
14.4V = 284uA
Don't care about 14.4V, that's floating charge voltage, nominal is 12-12.5V, and a small 55Ah battery will take 28 years to discharge at 223uA
