Sounds like a brown-out reset or (less likely) stack over/underflow reset to me...
To get meaningful information out of the RCON register, you need to manually set the POR and BOR bits after checking the RCON register at boot-up.
Procedure is as follows: Power-on > check RCON register > RCON = 00111111
This way, when the PIC randomly reboots next time, checking the RCON register will tell you what's going on. If the POR and BOR bits are clear again, it's a power-on reset. If POR is set and BOR is clear, it's a brown-out reset (but only if you're using the internal voltage regulator for VDDCORE). See section 5.0 (RESET) in the datasheet, and specifically section 5.4.1. (Ref. the latest DS from Mchip's website).
It's also possible it's a stack overflow reset, although at 31 levels deep it's unlikely. I use MikroC, not MikcoB, but the library functions can sometimes use a lot of stack overhead, especially if interrupts are enabled. Look at the 'Functions Tree' section under View > Statistics in the compiler. You can see the function dependencies - ie how many calls within calls you have. Don't forget to add one for the interrupt routine.
Also, always read the errata. Very important! There's stuff in there about the EUSART and oscillator. A mis-configured oscillator/PLL could cause this. If you have an early chip revision you need to pay attention to every point listed. See
http://ww1.microchip.com/downloads/en/DeviceDoc/80503e.pdfYou also need to check the interrupt routine is doing it's context saving correctly. You'll need to do this in the disassembly listing (View > Listing). I had a problem on an older version of MikroC where the interrupt routine was not saving context correctly (compiler issue). The PIC does hardware context saving in some circumstances, but might not. See datasheet page 138.
Also, on page 119 of the datasheet it says:
NOTE - Do not use the MOVFF instruction to modify any of the Interrupt Control registers while any interrupt is enabled. Doing so may cause erratic microcontroller behavior. Check the disassembly listing to see if any of the INTCON, PIR or PIE registers are modified using this instruction.
Failing all that, plough through the disassembly listing to see if anything looks unusual. But if you're not familiar with the PIC architecture, that might be tricky.
Good luck!
