Author Topic: PIC18 TMR2 Random Long Pulse? (Screencaps)  (Read 1887 times)
Offline klr5205Topic starter
« on: May 15, 2018, 01:46:25 pm »
Does anybody have any traps for young players that would be likely to cause an intermittent long pulse from TMR2 and/or the non-blocking delay function written below?
My program is purely interrupt driven except for a hearbeat signal I thought I would add as an afterthought.  I set up TMR2 to generate approximately 1ms system interrupts, and increment an unsigned long 'currentSystemTime' at each tick.  I have a generic delay function:
void delayMilliseconds(unsigned long ms) {            // ms: duration
    unsigned long start = currentSystemTime;          // start: timestamp
    for (;;) {
        unsigned long now = currentSystemTime;        // now: timestamp
        unsigned long elapsed = now - start;          // elapsed: duration
        if (elapsed >= ms)                            // comparing durations: OK
            return;
And I use it in a heartbeat function.  My ISR decides if it's been 1000 counts since the last heartbeat. If so, it sets a flag which triggers the following code to run:
if (statusFlag){
        for(int i=0; i<2; i++){
                STATUS_LED_SetLow();
                delayMilliseconds(100);
                //__delay_ms(100);
                STATUS_LED_SetHigh();
                //__delay_ms(100);
            statusFlag = 0;
            lastTime = currentSystemTime;
I get several pulses that look perfectly fine, but I get random intervals where a particularly long pulse is followed by a short pulse... the sum of which is still less than what a "good" period should be.  Take a look at the screenshots below to see what I mean:
"Good" Pulse
"Bad" Pulse
Processor is a PIC18F47K40
TMR2 not used for anything else besides 1ms tick.
TMR0 is used in oneshot mode for firing a triac.  (not during screencaps)
EUSART1 is used to received 9600 baud data.    (no data being received during screencaps)
This is pretty vexing behavior to me, although I'm a mostly self-taught, fairly unseasoned mcu programmer.  Any ideas where to look?
Offline agehall
Re: PIC18 TMR2 Random Long Pulse? (Screencaps)
« Reply #1 on: May 15, 2018, 01:55:57 pm »
First of all, I would recommend using specified integer sizes. unsigned long is always dodgy for things like this as one is never certain how big they are.
The most apparent problem I see in your code, is what happens when currentSystemTime wraps around. That could wreck havoc on your system.
« Reply #2 on: May 15, 2018, 02:12:30 pm »
I thought using an unsigned variable here was the more or less accepted way of dealing with the rollover of currentSystemTime  (or whatever variable).
Copied from a stackexchange post:
An unsigned long is 0 to 4,294,967,295 (2^32 - 1).
So lets say previousMillis is 4,294,967,290 (5 ms before rollover), and currentMillis is 10 (10ms after rollover). Then currentMillis - previousMillis is actual 16 (not -4,294,967,280) since the result will be calculated as an unsigned long (which can't be negative, so itself will roll around). You can check this simply by:
Serial.println( ( unsigned long ) ( 10 - 4294967290 ) ); // 16
So the above code will work perfectly fine. The trick is to always calculate the time difference, and not compare the two time values
Offline NorthGuy
« Reply #3 on: May 15, 2018, 02:47:27 pm »
If your "interrupt driven code" uses all of the processor time, the main loop doesn't get any chance to execute. I guess that's what you're observing. Disable all interrupts except TMR2 and see if you get a good pulse.
« Reply #4 on: May 15, 2018, 03:02:41 pm »
Based on your comment I changed my delay function and all related variables to unsigned int and the problem seems to have gone away... although I have my scope monitoring for a short pulse
For my purposes I think this is completely acceptable... but what if I truly needed an unsigned long?
Online Ian.M
« Reply #5 on: May 15, 2018, 03:08:00 pm »
XC8 can be configured to use either 24 bit or 32 bit longs.  For the sake of your sanity use ANSI C99 standard fixed width types from stdint.h.  See: https://en.wikipedia.org/wiki/C_data_types#Fixed-width_integer_types
See XC8's  stdint.h for which C99 types are supported.
« Last Edit: May 15, 2018, 03:13:20 pm by Ian.M »
Offline mikerj
« Reply #6 on: May 15, 2018, 03:25:13 pm »
The basic problem here is that reading and writing a 24/32 bit value on an 8 bit micro is not an atomic operation.  This means that a simple expression such as:
can end up with a very incorrect time value in 'now', since in the process of copying the 3/4 bytes of 'currentSystemTime' the timer interrupt could fire and change the value of currentSystemTime.  The simple fix for this is to disable the relevant interrupt whilst reading or writing multi-byte words in your main loop, which are also accessed by interrupts.  You should also declare the currentSystemTime variable as volatile.
PIE4 &= ~TMR2IE; /* Disable timer 2 interrupt whilst accessing 'currentSystemTime' */
PIE4 |= TMR2IE; /* Re-enable timer 2 interrupt */
The register/bit names for timer 2 interrupt enable in the above code may not be correct for your compiler, it's just an example of what needs to be done.
Note that using a 16 bit int has not fixed your problem, it has reduced the opportunity for it to fail but it will undoubtedly fail at some point.
« Last Edit: May 15, 2018, 03:26:45 pm by mikerj »
The following users thanked this post: Ian.M, JPortici
« Reply #7 on: May 15, 2018, 07:28:53 pm »
I left my scope armed to catch a short pulse all afternoon while I did something else and it didn't catch any "bad" pulses which if it is truly doomed to fail again as it is coded  is a huge improvement vs having a bad pulses every several seconds like before.
However, I do understand and take your point about disabling timer 2 interrupts when I read currentSystemTime and I will do that.
Thanks!
Offline cv007
« Reply #8 on: May 15, 2018, 10:29:24 pm »
since you are blocking on the delay, simplify-
void delayMilliseconds(uint16_t ms){ // 0 - 65535 ms
  for( ; ms; __delay_ms(1), ms-- );
unless there are other reasons for 'currentSystemTime', it could be eliminated and the tmr2 simply has to keep track of when 1 second has elapsed and set a flag (as is currently done), then no atomic access issues
if 'currentSystemTime' is also needed for timestamp reasons, or non-blocking delays, etc.,  I think I would still go the simple route for a blocking ms delay function
also, since you are only reading 'currentSystemTime', an alternate way is to check if the read was atomic
uint32_t t;
while( t = currentSystemTime, currentSystemTime != t );
although just clearing/setting the tmr2 irq is easy enough, and probably better
Offline agehall
« Reply #9 on: May 16, 2018, 05:17:22 am »
I always try to use uint32_t or whatever type I need. That way I know how big my datatype is by just reading the code which I find much easier than any alternatives. There are cases where you cannot use these types or where it becomes cumbersome and in those cases I try to be very careful about what I do with the data - there is always a chance you overflow the integer by accident if you don't know what you are dealing with...
The following users thanked this post: TomS_
« Reply #10 on: May 16, 2018, 01:24:43 pm »
This is a good point and I'm a little disappointed that I didn't recognize what feels obvious at this point lol.  I don't need (or even use) a timestamp whatsoever so why try so hard to keep track of system time?
I can just create a milliFlag that gets toggled at each 1ms interrupt and then do this:
void delayMilliseconds(int delay){
    int numMillis = 0;
    bool toggle = 0;
    while(numMillis < delay){
      if(toggle != milliFlag){
        numMillis++;
        toggle = milliFlag;
This seems simpler and less error prone than messing around large integers that can apparently cause issues due to the compiler (or my lack of understanding of it :-DD)
Offline cv007
« Reply #11 on: May 16, 2018, 03:29:16 pm »
Then you don't even need timer2 to do anything, and you can simply do this in your main-
for(;;){
    __delay_ms(800);
    __delay_ms(200);
those delays are simply inlined time killers, and as long as you have _XTAL_FREQ defined (which you most likely already do), they work just as well as a timer without having to use a timer
if you need delays that can change at runtime through variables, then a generic delay_ms function can be created as I showed previously
Offline NorthGuy
« Reply #12 on: May 16, 2018, 03:37:49 pm »
Not exactly as well. All the time spent in interrupts while you're throttling is added to the delay, so if there's a heavy interrupt load your delay may be much longer than intended. This is not a problem with the timer, because the timer keeps going while the CPU processes the ISRs.
Offline cv007
« Reply #13 on: May 16, 2018, 04:06:54 pm »
True, but with the latest code shown the delay function would would never know anyway as its looking for a flag (the timer could be toggling the flag multiple times- the delay function would never know). I would assume since this is a 'heartbeat' indicator, the actual delay time precision is not important, and the added benefit of not using a precise timer method is you could see the effects of an isr that takes too much time for some reason (although I would have a hard time believing the mcu could be that busy given the info provided- tmr0 doing a one-shot, uart doing 9600 baud).
There may be better ways than just blinking the led at a 'constant' interval to indicate activity, which only indicates that a main loop is running- maybe it would be nicer to show tmr0 and/or uart activity. Just a thought.
