Can you design and create a Raman for me for $1000 so I can return back to my niece school before I break it?
I don't know anything about optics or mechanics designs. I doubt one person can realistically build anything like this. I would 200x the budget if you want to find anyone even willing to talk.
How can a terminal shows up ascii or garbage depending on the baud rate? Can you just show in simple example how garbage can show up depending on baud rate?
You have 256000 BPS selected, which is again highly non-standard. Change that number and see how the output varies. This is the garbage I'm talking about. You need to try more standard baudrates. Which ones are standard - google.
Before we end this thread (yes I'll self moderate and stop. I thought reverse engineering is allowable, how does it differ to theft anyway I sometimes wondered in the past). I want to know the following.
I tried all kinds of baud rates in Device Manager and settled with 9600. And the outputs are the same. The Raman app won't let you change any baud rate, and note the application Serial Port Monitor is NOT a terminal. It just shows what goes on in the Raman app as it receives data. It can't adjust baud rate. Without any app that uses the serial. The Serial Port Monitor won't have any output. What do you call this serial sniffing software?
Note the 256000 BPS you saw in Serial Port Monitor is the Send Dialog box, which doesn't function because you are receiving data and not sending, one can adjust it down to 110 baud when sending dialog (and it is not relevant to the receiving application. .
For my last question (I know now I shouldn't announce whenever I got new firmware) I just want to know if you have any ideas how to convert the following data to the raman plot (of H20 water) ni the graph. Any pattern you are familiar with (there is 00 every 4th, 8th, 12th, 16th? Is it Unsigned 8 bit raw for example or Signed when converting in Audacity which I learnt from Ozcar? And Signed means someone signed them? Many thanks.
76 35 00 00 b6 34 00 00 17 36 00 00 98 36 00 00 v5..¶4...6..˜6..
3c 34 00 00 69 35 00 00 4c 36 00 00 dd 34 00 00 <4..i5..L6..Ý4..
ad 34 00 00 dc 35 00 00 2a 35 00 00 c6 35 00 00 4..Ü5..*5..Æ5..
bf 33 00 00 1f 35 00 00 9c 33 00 00 b5 35 00 00 ¿3...5..œ3..µ5..
ff 4a 01 00 1e 44 01 00 a1 5e 01 00 b6 55 01 00 ÿJ...D..¡^..¶U..
ba 4c 01 00 0d 4f 01 00 64 63 01 00 27 49 01 00 ºL...O..dc..'I..
db a6 01 00 25 44 01 00 81 4f 01 00 ae 42 01 00 Û¦..%D..O..®B..
ea 27 01 00 bc 5f 01 00 ee 81 01 00 93 8f 01 00 ê'..¼_..î..“..
54 6f 01 00 32 6f 01 00 cc 85 01 00 3c 91 01 00 To..2o..Ì…..<‘..
6f 86 01 00 fe 88 01 00 5b 68 01 00 69 89 01 00 o†..þˆ..[h..i‰..
6a 7b 01 00 cb a7 01 00 e9 ac 01 00 9d d0 01 00 j{..˧..é¬..Ð..
5f 02 02 00 39 72 02 00 c1 fa 02 00 bc 78 05 00 _...9r..Áú..¼x..
03 1c 0f 00 e7 ff 18 80 e7 ff 18 80 e7 ff 18 80 ....çÿ.€çÿ.€çÿ.€
e7 ff 18 80 e7 ff 18 80 e7 ff 18 80 e7 ff 18 80 çÿ.€çÿ.€çÿ.€çÿ.€
e7 ff 18 80 54 d1 18 80 a1 fd 17 80 4c 97 02 00 çÿ.€TÑ.€¡ý.€L—..
4f 8c 02 00 6d 25 02 00 1a 22 02 00 8f 37 02 00 OŒ..m%..."..7..
8b 42 02 00 ff f5 01 00 3a f1 01 00 8d b5 01 00 ‹B..ÿõ..:ñ..µ..
da 93 01 00 22 89 01 00 d3 82 01 00 1f 96 01 00 Ú“.."‰..Ó‚...–..
d1 cc 01 00 6f a4 01 00 1b a6 01 00 11 91 01 00 ÑÌ..o¤...¦...‘..
e9 82 01 00 1c 5a 01 00 07 71 01 00 94 6a 01 00 é‚...Z...q..”j..
b2 90 01 00 32 44 01 00 5b 77 01 00 46 77 01 00 ²..2D..[w..Fw..
38 a3 01 00 64 63 01 00 81 5c 01 00 2e 42 01 00 8£..dc..\...B..
24 47 01 00 a4 70 01 00 fc 71 01 00 a3 70 01 00 $G..¤p..üq..£p..
dc 39 01 00 bb 79 01 00 8c 8f 01 00 ce 6c 01 00 Ü9..»y..Œ..Îl..
57 4e 01 00 9c 7c 01 00 d8 55 01 00 3d 81 01 00 WN..œ|..ØU..=..
de 6b 01 00 6d e8 01 00 46 9d 01 00 0b 77 01 00 Þk..mè..F...w..
ca 7a 01 00 c7 80 01 00 d6 72 01 00 e9 ee 01 00 Êz..Ç€..Ör..éî..
6e a8 01 00 68 e1 01 00 0c 41 02 00 54 71 02 00 n¨..há...A..Tq..
1e 03 03 00 a6 86 03 00 2f 1a 04 00 51 d7 04 00 ....¦†../...Q×..
70 a7 05 00 e3 cc 05 00 f9 3c 06 00 67 66 06 00 p§..ãÌ..ù<..gf..
b1 b2 06 00 ad 9c 06 00 63 b5 06 00 1d d0 06 00 ±²..œ..cµ...Ð..
dc ea 06 00 a8 b1 06 00 9b eb 06 00 15 ee 06 00 Üê..¨±..›ë...î..
90 a1 06 00 34 95 06 00 1a ab 06 00 dd 8a 06 00 ¡..4•...«..ÝŠ..
6a 77 06 00 41 99 06 00 6b 96 06 00 26 af 06 00 jw..A™..k–..&¯..
fc 82 06 00 35 82 06 00 e9 82 06 00 cb 8e 06 00 ü‚..5‚..é‚..ËŽ..
9d 69 06 00 9c 5d 06 00 64 84 06 00 60 58 06 00 i..œ]..d„..`X..
51 35 06 00 1c 7c 06 00 ab 4e 06 00 37 1f 06 00 Q5...|..«N..7...
01 4f 06 00 a5 f7 05 00 9b 37 06 00 12 08 06 00 .O..¥÷..›7......
4d 22 06 00 b5 f2 05 00 0b fb 05 00 77 e1 05 00 M"..µò...û..wá..
f1 ee 05 00 77 d3 05 00 1d f0 05 00 1e e6 05 00 ñî..wÓ...ð...æ..
32 e5 05 00 37 a2 05 00 5f b3 05 00 24 a2 05 00 2å..7¢.._³..$¢..
6c b7 05 00 be b5 05 00 ca b8 05 00 55 73 05 00 l·..¾µ..ʸ..Us..
ae 7d 05 00 5b 71 05 00 30 99 05 00 8e 6e 05 00 ®}..[q..0™..Žn..
d5 36 05 00 a7 75 05 00 7a 2c 05 00 ec 34 05 00 Õ6..§u..z,..ì4..
6d 22 05 00 a2 15 05 00 52 16 05 00 66 f4 04 00 m"..¢...R...fô..
86 fc 04 00 2e f2 04 00 8c be 04 00 72 cd 04 00 †ü...ò..Œ¾..rÍ..
b1 f8 04 00 65 a1 04 00 ed cf 04 00 a4 b5 04 00 ±ø..e¡..íÏ..¤µ..
74 a5 04 00 d7 98 04 00 09 8b 04 00 75 93 04 00 t¥..ט...‹..u“..
b7 9a 04 00 51 75 04 00 17 63 04 00 a7 87 04 00 ·š..Qu...c..§‡..
02 77 04 00 38 2e 04 00 c8 99 04 00 c2 5f 04 00 .w..8...È™..Â_..
e6 5d 04 00 ae 61 04 00 96 4e 04 00 12 2a 04 00 æ]..®a..–N...*..
a3 34 04 00 ed 47 04 00 ec 47 04 00 ef 3f 04 00 £4..íG..ìG..ï?..
72 1c 04 00 65 24 04 00 4e 37 04 00 5d 00 04 00 r...e$..N7..]...
23 1d 04 00 67 2e 04 00 bd ff 03 00 60 f4 03 00 #...g...½ÿ..`ô..
b0 0e 04 00 52 56 04 00 04 4f 04 00 71 f1 03 00 °...RV...O..qñ..
6d 03 04 00 4c f2 03 00 c7 0b 04 00 dd 1e 04 00 m...Lò..Ç...Ý...
e8 f1 03 00 31 d8 03 00 65 c6 03 00 89 d9 03 00 èñ..1Ø..eÆ..‰Ù..
24 f9 03 00 01 25 04 00 2a cc 03 00 e4 dc 03 00 $ù...%..*Ì..äÜ..
fd e6 03 00 cc ee 03 00 b6 e5 03 00 79 d8 03 00 ýæ..Ìî..¶å..yØ..
06 e9 03 00 93 fb 03 00 76 e0 03 00 5d e0 03 00 .é..“û..và..]à..
62 0f 04 00 e6 c3 03 00 92 c3 03 00 47 d6 03 00 b...æÃ..’Ã..GÖ..
a2 ed 03 00 da 3e 04 00 29 b7 03 00 1f c8 03 00 ¢í..Ú>..)·...È..
e1 fb 03 00 d3 c5 03 00 ed d2 03 00 d7 c4 03 00 áû..ÓÅ..íÒ..×Ä..
e2 f1 03 00 3a d6 03 00 c3 e3 03 00 17 e5 03 00 âñ..:Ö..Ãã...å..
c6 d1 03 00 2b 30 04 00 ee 21 04 00 51 22 04 00 ÆÑ..+0..î!..Q"..
e0 09 04 00 90 fd 03 00 78 e1 03 00 63 fe 03 00 à...ý..xá..cþ..
6e 33 04 00 6c f8 03 00 98 01 04 00 97 e2 03 00 n3..lø..˜...—â..
be f5 03 00 78 e5 03 00 20 e5 03 00 1b 15 04 00 ¾õ..xå.. å......
da ff 03 00 c8 d3 03 00 bc 0f 04 00 da fb 03 00 Úÿ..ÈÓ..¼...Úû..
d3 d7 03 00 88 04 04 00 2d 10 04 00 aa 1d 04 00 Ó×..ˆ...-...ª...
ef 02 04 00 66 e4 03 00 88 f8 03 00 5e e0 03 00 ï...fä..ˆø..^à..
73 08 04 00 93 f0 03 00 3d 0b 04 00 7b f5 03 00 s...“ð..=...{õ..
3f 0d 04 00 fa 1d 04 00 cf f7 03 00 63 e7 03 00 ?...ú...Ï÷..cç..
f4 31 04 00 29 e6 03 00 b7 f0 03 00 32 2a 04 00 ô1..)æ..·ð..2*..
16 1d 04 00 b4 0a 04 00 10 0b 04 00 0b f3 03 00 ....´........ó..
18 1d 04 00 f6 05 04 00 ee 34 04 00 d5 fa 03 00 ....ö...î4..Õú..
4f ee 03 00 98 12 04 00 dd 54 04 00 04 00 04 00 Oî..˜...ÝT......
65 0f 04 00 96 26 04 00 6a 2e 04 00 f7 26 04 00 e...–&..j...÷&..
c8 33 04 00 4c 57 04 00 6c 4f 04 00 85 35 04 00 È3..LW..lO..…5..
6a 4c 04 00 44 26 04 00 2c 30 04 00 ea 72 04 00 jL..D&..,0..êr..
27 48 04 00 cf 3e 04 00 9c 74 04 00 a1 15 04 00 'H..Ï>..œt..¡...
b6 64 04 00 b8 2d 04 00 55 3c 04 00 b1 36 04 00 ¶d..¸-..U<..±6..
cf 27 04 00 fd 7c 04 00 f1 4b 04 00 52 1e 04 00 Ï'..ý|..ñK..R...
bb 30 04 00 cb 3d 04 00 e1 61 04 00 66 32 04 00 »0..Ë=..áa..f2..
c0 4f 04 00 4e 22 04 00 f1 83 04 00 2b 3c 04 00 ÀO..N"..ñƒ..+<..
7e 1c 04 00 e9 0f 04 00 01 3c 04 00 8f 1d 04 00 ~...é....<.....
9f 3a 04 00 b1 05 04 00 85 25 04 00 1e 25 04 00 Ÿ:..±...…%...%..
0a 19 04 00 0b 36 04 00 fb 23 04 00 26 58 04 00 .....6..û#..&X..
b6 29 04 00 78 19 04 00 4c 25 04 00 2e e2 03 00 ¶)..x...L%...â..
62 28 04 00 1c 02 04 00 fa 02 04 00 cb da 03 00 b(......ú...ËÚ..
59 c9 03 00 36 d6 03 00 01 df 03 00 eb ad 03 00 YÉ..6Ö...ß..ë..
e3 b1 03 00 08 80 03 00 15 96 03 00 7f 87 03 00 ã±...€...–..‡..
bd 64 03 00 86 64 03 00 11 89 03 00 16 53 03 00 ½d..†d...‰...S..
a4 53 03 00 d6 47 03 00 69 35 03 00 52 3a 03 00 ¤S..ÖG..i5..R:..
56 51 03 00 0d 23 03 00 e3 4d 03 00 35 26 03 00 VQ...#..ãM..5&..
0a 3b 03 00 0e 0c 03 00 83 23 03 00 7b 1f 03 00 .;......ƒ#..{...
b5 0e 03 00 a8 04 03 00 43 11 03 00 d1 10 03 00 µ...¨...C...Ñ...
4a 0f 03 00 e9 12 03 00 32 27 03 00 74 13 03 00 J...é...2'..t...
5f e1 02 00 24 0f 03 00 33 e2 02 00 71 17 03 00 _á..$...3â..q...
06 fa 02 00 5c da 02 00 f2 f0 02 00 da cd 02 00 .ú..\Ú..òð..ÚÍ..
0d d4 02 00 20 f9 02 00 2c cc 02 00 dd cd 02 00 .Ô.. ù..,Ì..ÝÍ..
b4 d5 02 00 64 c6 02 00 f6 00 03 00 dc da 02 00 ´Õ..dÆ..ö...ÜÚ..
70 c4 02 00 3e c2 02 00 26 ac 02 00 15 a7 02 00 pÄ..>Â..&¬...§..
24 e8 02 00 a2 b4 02 00 01 d3 02 00 a6 cf 02 00 $è..¢´...Ó..¦Ï..
b8 b6 02 00 80 9a 02 00 ac c3 02 00 04 d8 02 00 ¸¶..€š..¬Ã...Ø..
2d cd 02 00 3b 95 02 00 2f ac 02 00 72 a4 02 00 -Í..;•../¬..r¤..
f9 b2 02 00 ce aa 02 00 f5 a1 02 00 3e 9f 02 00 ù²..Ϊ..õ¡..>Ÿ..
61 9c 02 00 9d 8d 02 00 1c b3 02 00 d8 aa 02 00 aœ.....³..ت..
2a 98 02 00 14 a4 02 00 39 7e 02 00 e4 c3 02 00 *˜...¤..9~..äÃ..
c9 9e 02 00 6d 73 02 00 8a cc 02 00 10 91 02 00 Éž..ms..ŠÌ...‘..
42 83 02 00 cd 97 02 00 92 c5 02 00 42 a3 02 00 Bƒ..Í—..’Å..B£..
51 8f 02 00 b0 c4 02 00 38 93 02 00 eb 82 02 00 Q..°Ä..8“..ë‚..
c8 7e 02 00 26 8c 02 00 2b 9b 02 00 0b 98 02 00 È~..&Œ..+›...˜..
3d 78 02 00 0c 7a 02 00 15 8c 02 00 6d 87 02 00 =x...z...Œ..m‡..
bf 5d 02 00 67 9a 02 00 f3 a7 02 00 c6 66 02 00 ¿]..gš..ó§..Æf..
db 6d 02 00 6b 5c 02 00 a3 73 02 00 7c 96 02 00 Ûm..k\..£s..|–..
ef 75 02 00 b0 4e 02 00 48 89 02 00 4c 60 02 00 ïu..°N..H‰..L`..
09 75 02 00 96 64 02 00 74 7e 02 00 b2 62 02 00 .u..–d..t~..²b..
e9 6c 02 00 85 4b 02 00 77 6f 02 00 95 9b 02 00 él..…K..wo..•›..
35 56 02 00 d1 79 02 00 c9 72 02 00 89 8c 02 00 5V..Ñy..Ér..‰Œ..
55 5d 02 00 82 5f 02 00 89 6f 02 00 10 32 02 00 U]..‚_..‰o...2..
3e 34 02 00 cd 4b 02 00 ac 78 02 00 0d 77 02 00 >4..ÍK..¬x...w..
50 85 02 00 cc 6a 02 00 a2 71 02 00 48 7c 02 00 P…..Ìj..¢q..H|..
96 4b 02 00 14 6e 02 00 bf 66 02 00 60 8d 02 00 –K...n..¿f..`..
21 4b 02 00 1c 5d 02 00 a2 67 02 00 a6 3c 02 00 !K...]..¢g..¦<..
d9 71 02 00 7e 4a 02 00 13 57 02 00 04 88 02 00 Ùq..~J...W...ˆ..
89 2f 02 00 39 75 02 00 60 2b 02 00 cf 8a 02 00 ‰/..9u..`+..ÏŠ..
21 5c 02 00 ee 42 02 00 8c 62 02 00 9c 52 02 00 !\..îB..Œb..œR..
99 4d 02 00 ff 92 02 00 fb 5c 02 00 b5 61 02 00 ™M..ÿ’..û\..µa..
fa 89 02 00 68 34 02 00 f3 52 02 00 76 44 02 00 ú‰..h4..óR..vD..
6d 8e 02 00 38 56 02 00 df 4b 02 00 8d 77 02 00 mŽ..8V..ßK..w..
ea 4d 02 00 d9 41 02 00 af 7b 02 00 b4 4f 02 00 êM..ÙA..¯{..´O..
09 4c 02 00 4e 48 02 00 b6 82 02 00 1d 50 02 00 .L..NH..¶‚...P..
41 4c 02 00 33 55 02 00 32 43 02 00 5d 72 02 00 AL..3U..2C..]r..
93 78 02 00 d9 75 02 00 b5 3d 02 00 dd 5b 02 00 “x..Ùu..µ=..Ý[..
09 43 02 00 3f 2d 02 00 d4 43 02 00 b4 43 02 00 .C..?-..ÔC..´C..
8b 74 02 00 bd 3d 02 00 06 53 02 00 b4 43 02 00 ‹t..½=...S..´C..
45 67 02 00 ff 50 02 00 a6 84 02 00 f4 50 02 00 Eg..ÿP..¦„..ôP..
82 6c 02 00 4f 6e 02 00 4e 53 02 00 de 2d 02 00 ‚l..On..NS..Þ-..
d5 54 02 00 37 3b 02 00 f2 34 02 00 20 6a 02 00 ÕT..7;..ò4.. j..
45 4d 02 00 ab 57 02 00 3e 57 02 00 57 43 02 00 EM..«W..>W..WC..
9a 4d 02 00 ac 3f 02 00 97 71 02 00 9f 2c 02 00 šM..¬?..—q..Ÿ,..
d4 27 02 00 86 41 02 00 39 46 02 00 19 34 02 00 Ô'..†A..9F...4..
d9 4f 02 00 47 2b 02 00 e5 81 02 00 fe 4e 02 00 ÙO..G+..å..þN..
02 4e 02 00 46 1a 02 00 83 2e 02 00 b2 63 02 00 .N..F...ƒ...²c..
08 49 02 00 72 22 02 00 24 32 02 00 e2 2f 02 00 .I..r"..$2..â/..
cc 61 02 00 00 2c 02 00 97 43 02 00 07 1f 02 00 Ìa...,..—C......
71 1f 02 00 00 1a 02 00 cf 1e 02 00 fc 0e 02 00 q.......Ï...ü...
fd 1f 02 00 9f 04 02 00 e6 26 02 00 bd 21 02 00 ý...Ÿ...æ&..½!..
b1 10 02 00 cf 0c 02 00 60 42 02 00 88 20 02 00 ±...Ï...`B..ˆ ..
f6 13 02 00 d5 2a 02 00 23 20 02 00 69 08 02 00 ö...Õ*..# ..i...
e0 2c 02 00 84 44 02 00 60 3d 02 00 e9 0b 02 00 à,..„D..`=..é...
ac fd 01 00 72 0f 02 00 10 0b 02 00 44 06 02 00 ¬ý..r.......D...
47 1c 02 00 aa 1a 02 00 70 50 02 00 4e f8 01 00 G...ª...pP..Nø..
bd 02 02 00 f5 01 02 00 28 21 02 00 61 40 02 00 ½...õ...(!..a@..
4b 53 02 00 84 21 02 00 28 ff 01 00 bb 21 02 00 KS..„!..(ÿ..»!..
61 ea 01 00 41 f3 01 00 40 33 02 00 93 42 02 00 aê..Aó..@3..“B..
fc 14 02 00 a0 1f 02 00 a6 39 02 00 97 42 02 00 ü... ...¦9..—B..
30 31 02 00 c0 02 02 00 bd 18 02 00 27 2b 02 00 01..À...½...'+..
91 2c 02 00 ec e8 01 00 f7 63 02 00 56 ff 01 00 ‘,..ìè..÷c..Vÿ..
f7 2a 02 00 11 4f 02 00 ae 1e 02 00 32 26 02 00 ÷*...O..®...2&..
b6 de 01 00 e9 e6 01 00 a7 04 02 00 da 24 02 00 ¶Þ..éæ..§...Ú$..
8d 1f 02 00 04 19 02 00 3f 1a 02 00 2e d8 01 00 .......?....Ø..
30 17 02 00 82 1d 02 00 50 2f 02 00 ac 02 02 00 0...‚...P/..¬...
32 0f 02 00 9a 05 02 00 4d 0b 02 00 a6 03 02 00 2...š...M...¦...
ed 0b 02 00 3a 0c 02 00 0e 01 02 00 a4 3d 02 00 í...:.......¤=..
f9 08 02 00 11 01 02 00 a4 42 02 00 92 fe 01 00 ù.......¤B..’þ..
a7 f6 01 00 2a e5 01 00 f2 17 02 00 ba 06 02 00 §ö..*å..ò...º...
da 08 02 00 77 12 02 00 bd 2c 02 00 5b f8 01 00 Ú...w...½,..[ø..
e1 12 02 00 67 fc 01 00 f8 ff 01 00 f0 15 02 00 á...gü..øÿ..ð...
14 04 02 00 2a f9 01 00 57 05 02 00 30 1a 02 00 ....*ù..W...0...
ef 2b 02 00 fa ed 01 00 cb 20 02 00 b3 1c 02 00 ï+..úí..Ë ..³...
e9 26 02 00 59 29 02 00 0b 23 02 00 26 34 02 00 é&..Y)...#..&4..
72 2d 02 00 1a 09 02 00 92 16 02 00 9f 05 02 00 r-......’...Ÿ...
92 f3 01 00 7b 09 02 00 0b 1b 02 00 74 1e 02 00 ’ó..{.......t...
51 2b 02 00 95 0c 02 00 55 00 02 00 39 0b 02 00 Q+..•...U...9...
60 26 02 00 ef 0e 02 00 71 2c 02 00 40 03 02 00 `&..ï...q,..@...
de fe 01 00 41 29 02 00 81 16 02 00 43 ec 01 00 Þþ..A).....Cì..
74 29 02 00 65 0c 02 00 59 48 02 00 bb 13 02 00 t)..e...YH..»...
48 1a 02 00 ae 06 02 00 cc 48 02 00 8c 3b 02 00 H...®...ÌH..Œ;..
ac 2d 02 00 e7 41 02 00 99 28 02 00 d5 08 02 00 ¬-..çA..™(..Õ...
81 0f 02 00 d7 0b 02 00 6f 1d 02 00 08 11 02 00 ...×...o.......
7f 00 02 00 15 ec 01 00 7f 32 02 00 f6 0f 02 00 ....ì..2..ö...
a9 1b 02 00 95 17 02 00 77 16 02 00 96 07 02 00 ©...•...w...–...
51 fa 01 00 8d f2 01 00 85 33 02 00 75 34 02 00 Qú..ò..…3..u4..
86 ee 01 00 30 03 02 00 18 27 02 00 73 fb 01 00 †î..0....'..sû..
c2 09 02 00 98 e1 01 00 e0 30 02 00 f7 02 02 00 Â...˜á..à0..÷...
a8 11 02 00 a1 29 02 00 a0 f9 01 00 39 37 02 00 ¨...¡).. ù..97..
01 00 02 00 13 09 02 00 0f 2b 02 00 d8 78 02 00 .........+..Øx..
2f 12 02 00 f3 ff 01 00 6d 1e 02 00 69 2c 02 00 /...óÿ..m...i,..
7a 2c 02 00 16 05 02 00 92 21 02 00 66 32 02 00 z,......’!..f2..
73 ff 01 00 a1 23 02 00 e4 14 02 00 88 1b 02 00 sÿ..¡#..ä...ˆ...
12 0e 02 00 44 fd 01 00 61 32 02 00 b4 24 02 00 ....Dý..a2..´$..
01 2f 02 00 d0 fe 01 00 db 0f 02 00 09 0d 02 00 ./..Ðþ..Û.......
bc fa 01 00 ed 12 02 00 51 35 02 00 28 02 02 00 ¼ú..í...Q5..(...
a6 0a 02 00 34 06 02 00 36 1c 02 00 82 32 02 00 ¦...4...6...‚2..
99 13 02 00 6b 17 02 00 19 31 02 00 b1 1b 02 00 ™...k....1..±...
99 04 02 00 36 07 02 00 17 08 02 00 55 20 02 00 ™...6.......U ..
1c 05 02 00 7a 1b 02 00 26 07 02 00 f4 08 02 00 ....z...&...ô...
11 33 02 00 c0 14 02 00 c4 09 02 00 59 05 02 00 .3..À...Ä...Y...
6e 1e 02 00 2d fa 01 00 0e 1a 02 00 20 25 02 00 n...-ú...... %..
fd 54 02 00 8a 22 02 00 03 09 02 00 1d 3a 02 00 ýT..Š".......:..
e5 f7 01 00 9c f7 01 00 82 14 02 00 4c 09 02 00 å÷..œ÷..‚...L...
24 0e 02 00 85 ed 01 00 cf 03 02 00 69 f6 01 00 $...…í..Ï...iö..
6f 0b 02 00 60 04 02 00 e9 2c 02 00 f0 01 02 00 o...`...é,..ð...
10 23 02 00 cd 0e 02 00 e7 0b 02 00 87 ee 01 00 .#..Í...ç...‡î..
2d 04 02 00 40 04 02 00 b7 1c 02 00 10 08 02 00 -...@...·.......
06 25 02 00 0b fa 01 00 cb f5 01 00 32 3d 02 00 .%...ú..Ëõ..2=..
90 28 02 00 2e ec 01 00 9e e4 01 00 3e f7 01 00 (...ì..žä..>÷..
21 e7 01 00 2f de 01 00 d2 fe 01 00 7c fc 01 00 !ç../Þ..Òþ..|ü..
23 d6 01 00 d7 1b 02 00 e5 1f 02 00 a3 0c 02 00 #Ö..×...å...£...
37 ec 01 00 8d f3 01 00 21 1a 02 00 6a 22 02 00 7ì..ó..!...j"..
ab ce 01 00 40 e0 01 00 c3 f6 01 00 28 f1 01 00 «Î..@à..Ãö..(ñ..
20 f9 01 00 46 cf 01 00 d1 0b 02 00 10 f7 01 00 ù..FÏ..Ñ....÷..
d4 14 02 00 ac f3 01 00 92 3a 02 00 76 ec 01 00 Ô...¬ó..’:..vì..
35 ed 01 00 9e f7 01 00 72 10 02 00 05 11 02 00 5í..ž÷..r.......
16 dd 01 00 63 02 02 00 73 fd 01 00 bd d9 01 00 .Ý..c...sý..½Ù..
75 d3 01 00 37 c7 01 00 27 04 02 00 c5 f2 01 00 uÓ..7Ç..'...Åò..
c5 fb 01 00 2e ed 01 00 d0 f2 01 00 22 ee 01 00 Åû...í..Ðò.."î..
42 d9 01 00 ab f3 01 00 90 13 02 00 ef fe 01 00 BÙ..«ó.....ïþ..
ca 02 02 00 6d d6 01 00 51 f8 01 00 e3 da 01 00 Ê...mÖ..Qø..ãÚ..
b1 f3 01 00 2f ea 01 00 20 fe 01 00 35 44 02 00 ±ó../ê.. þ..5D..
cb ce 01 00 9d ea 01 00 51 d4 01 00 cf ec 01 00 ËÎ..ê..QÔ..Ïì..
7e fb 01 00 df 05 02 00 c8 26 02 00 7c f0 01 00 ~û..ß...È&..|ð..
ab d4 01 00 18 bb 01 00 fe 27 02 00 41 05 02 00 «Ô...»..þ'..A...
09 22 02 00 dd cb 01 00 66 39 02 00 93 03 02 00 ."..ÝË..f9..“...
4f dd 01 00 99 ea 01 00 f4 e4 01 00 56 f4 01 00 OÝ..™ê..ôä..Vô..
59 07 02 00 54 f2 01 00 35 2d 02 00 28 1e 02 00 Y...Tò..5-..(...
5e e8 01 00 b7 fd 01 00 dd f4 01 00 63 2d 02 00 ^è..·ý..Ýô..c-..
1e e1 01 00 84 dc 01 00 af f2 01 00 00 ef 01 00 .á..„Ü..¯ò...ï..
6e 01 02 00 73 df 01 00 f9 e4 01 00 84 0f 02 00 n...sß..ùä..„...
8b db 01 00 45 df 01 00 c1 23 02 00 4b f5 01 00 ‹Û..Eß..Á#..Kõ..
a1 d6 01 00 14 e8 01 00 dd ee 01 00 c8 e7 01 00 ¡Ö...è..Ýî..Èç..
5d dc 01 00 2e ef 01 00 10 f0 01 00 e5 f3 01 00 ]Ü...ï...ð..åó..
38 05 02 00 7c fb 01 00 40 1c 02 00 64 08 02 00 8...|û..@...d...
e1 e8 01 00 61 1a 02 00 bf d9 01 00 72 e9 01 00 áè..a...¿Ù..ré..
6c d2 01 00 5a eb 01 00 aa 10 02 00 85 f5 01 00 lÒ..Zë..ª...…õ..
e0 cc 01 00 4b f6 01 00 69 e5 01 00 f0 e5 01 00 àÌ..Kö..iå..ðå..
27 e0 01 00 a5 cf 01 00 cc 08 02 00 94 f4 01 00 'à..¥Ï..Ì...”ô..
7f d7 01 00 0b dc 01 00 41 f2 01 00 10 de 01 00 ×...Ü..Aò...Þ..
04 02 02 00 42 df 01 00 81 e6 01 00 e4 df 01 00 ....Bß..æ..äß..
02 15 02 00 41 fc 01 00 c9 ea 01 00 56 e0 01 00 ....Aü..Éê..Và..
8f e5 01 00 dd c7 01 00 32 f8 01 00 3d 1b 02 00 å..ÝÇ..2ø..=...
98 ed 01 00 af ca 01 00 df fc 01 00 1c cd 01 00 ˜í..¯Ê..ßü...Í..
06 c4 01 00 f4 fa 01 00 cc fc 01 00 67 1b 02 00 .Ä..ôú..Ìü..g...
cb cc 01 00 eb e2 01 00 65 f3 01 00 d3 ea 01 00 ËÌ..ëâ..eó..Óê..
20 e3 01 00 f6 d1 01 00 95 0d 02 00 61 eb 01 00 ã..öÑ..•...aë..
57 ce 01 00 a1 a9 01 00 e7 fc 01 00 79 b5 01 00 WÎ..¡©..çü..yµ..
17 da 01 00 81 dc 01 00 ca 05 02 00 57 e8 01 00 .Ú..Ü..Ê...Wè..
ee d1 01 00 d9 d3 01 00 7e 09 02 00 cb f4 01 00 îÑ..ÙÓ..~...Ëô..
ee d9 01 00 aa e3 01 00 be 14 02 00 96 f3 01 00 îÙ..ªã..¾...–ó..
54 d8 01 00 b0 db 01 00 95 18 02 00 27 d4 01 00 TØ..°Û..•...'Ô..
68 d8 01 00 8c f7 01 00 5d fb 01 00 58 c9 01 00 hØ..Œ÷..]û..XÉ..
22 37 02 00 a0 db 01 00 0e e8 01 00 64 e9 01 00 "7.. Û...è..dé..
6b f1 01 00 0e ff 01 00 ef d0 01 00 16 c7 01 00 kñ...ÿ..ïÐ...Ç..
dd c9 01 00 3a d3 01 00 8b ea 01 00 85 cd 01 00 ÝÉ..:Ó..‹ê..…Í..
98 f1 01 00 a6 d3 01 00 42 d8 01 00 8e f0 01 00 ˜ñ..¦Ó..BØ..Žð..
4a be 01 00 50 da 01 00 4c f5 01 00 b6 ef 01 00 J¾..PÚ..Lõ..¶ï..
2e 11 02 00 08 e8 01 00 ef f4 01 00 fb 04 02 00 .....è..ïô..û...
20 e0 01 00 5a c0 01 00 56 f6 01 00 61 e7 01 00 à..ZÀ..Vö..aç..
9d ec 01 00 2b b7 01 00 62 0d 02 00 95 e8 01 00 ì..+·..b...•è..
52 d9 01 00 99 ec 01 00 a6 1a 02 00 0e cc 01 00 RÙ..™ì..¦....Ì..
29 e2 01 00 4a e7 01 00 be f6 01 00 fe dc 01 00 )â..Jç..¾ö..þÜ..
99 d7 01 00 90 ed 01 00 3d fd 01 00 1a d2 01 00 ™×..í..=ý...Ò..
c5 e5 01 00 25 ba 01 00 85 e0 01 00 d4 d2 01 00 Åå..%º..…à..ÔÒ..
8d e2 01 00 c4 0b 02 00 93 e3 01 00 75 cf 01 00 â..Ä...“ã..uÏ..
b8 e3 01 00 07 d2 01 00 a4 db 01 00 7d 40 02 00 ¸ã...Ò..¤Û..}@..
dc 09 02 00 93 e5 01 00 b1 d3 01 00 bc ed 01 00 Ü...“å..±Ó..¼í..
76 03 02 00 85 1f 02 00 53 f1 01 00 1a dc 01 00 v...…...Sñ...Ü..
9e d2 01 00 14 cc 01 00 91 e6 01 00 7f 03 02 00 žÒ...Ì..‘æ.....
b2 d7 01 00 bb f9 01 00 61 01 02 00 83 da 01 00 ²×..»ù..a...ƒÚ..
10 d7 01 00 d6 2f 02 00 69 cf 01 00 ac e6 01 00 .×..Ö/..iÏ..¬æ..
f6 05 02 00 92 c0 01 00 eb 23 02 00 65 cb 01 00 ö...’À..ë#..eË..
27 00 02 00 44 e9 01 00 f0 ea 01 00 f0 c4 01 00 '...Dé..ðê..ðÄ..
30 c7 01 00 45 f7 01 00 58 f1 01 00 5e 11 02 00 0Ç..E÷..Xñ..^...
2a d3 01 00 f2 ca 01 00 7b e9 01 00 1b 14 02 00 *Ó..òÊ..{é......
ab f2 01 00 b9 e4 01 00 4f f4 01 00 47 dc 01 00 «ò..¹ä..Oô..GÜ..
af ee 01 00 8d ec 01 00 04 f7 01 00 38 2f 02 00 ¯î..ì...÷..8/..
31 2b 02 00 0d c9 01 00 d6 10 02 00 ff e9 01 00 1+...É..Ö...ÿé..
f1 03 02 00 30 19 02 00 59 e4 01 00 b5 06 02 00 ñ...0...Yä..µ...
8a f0 01 00 30 f0 01 00 e3 fc 01 00 b1 e2 01 00 Šð..0ð..ãü..±â..
4e e4 01 00 02 e7 01 00 78 0f 02 00 c5 02 02 00 Nä...ç..x...Å...
5c fb 01 00 28 e3 01 00 ef 20 02 00 9c 04 02 00 \û..(ã..ï ..œ...
7a 28 02 00 fd 1b 02 00 1e 00 02 00 5d 04 02 00 z(..ý.......]...
34 0f 02 00 b6 f3 01 00 6c 11 02 00 3e 13 02 00 4...¶ó..l...>...
17 e9 01 00 40 00 02 00 f6 27 02 00 c3 30 02 00 .é..@...ö'..Ã0..
72 44 02 00 f3 e7 01 00 1a fe 01 00 05 f7 01 00 rD..óç...þ...÷..
25 05 02 00 48 09 02 00 b6 1f 02 00 77 f6 01 00 %...H...¶...wö..
35 38 02 00 66 e7 01 00 37 22 02 00 3f f7 01 00 58..fç..7"..?÷..
8c ff 01 00 5a 09 02 00 d1 04 02 00 0c 42 02 00 Œÿ..Z...Ñ....B..
d5 fa 01 00 08 3e 02 00 0e 2b 02 00 e2 1b 02 00 Õú...>...+..â...
b8 f0 01 00 eb 18 02 00 c0 00 02 00 ed 1f 02 00 ¸ð..ë...À...í...
b0 16 02 00 40 0f 02 00 d7 1c 02 00 a3 fd 01 00 °...@...×...£ý..
0f 3d 02 00 51 08 02 00 3a 32 02 00 aa 2f 02 00 .=..Q...:2..ª/..
86 eb 01 00 bd 1b 02 00 9c 00 02 00 35 ff 01 00 †ë..½...œ...5ÿ..
78 fd 01 00 e2 0b 02 00 dc 12 02 00 5a f9 01 00 xý..â...Ü...Zù..
0d e6 01 00 83 dc 01 00 0e 10 02 00 8b f6 01 00 .æ..ƒÜ......‹ö..
16 0a 02 00 07 3a 02 00 8d f0 01 00 92 29 02 00 .....:..ð..’)..
dc f2 01 00 8d 06 02 00 ff dc 01 00 2c e4 01 00 Üò.....ÿÜ..,ä..
6d 30 02 00 c0 e5 01 00 d8 07 02 00 6e d8 01 00 m0..Àå..Ø...nØ..
ed ef 01 00 77 dc 01 00 54 00 02 00 58 d8 01 00 íï..wÜ..T...XØ..
87 f7 01 00 22 f1 01 00 bb dc 01 00 b7 e9 01 00 ‡÷.."ñ..»Ü..·é..
3a 3f 02 00 ab 04 02 00 85 de 01 00 7f fc 01 00 :?..«...…Þ..ü..
03 bb 01 00 e5 e8 01 00 55 e7 01 00 f2 e7 01 00 .»..åè..Uç..òç..
fd e8 01 00 97 e4 01 00 07 cd 01 00 31 e6 01 00 ýè..—ä...Í..1æ..
73 f7 01 00 b1 a5 01 00 3e db 01 00 8f d0 01 00 s÷..±¥..>Û..Ð..
00 d3 01 00 fd d2 01 00 3e e9 01 00 16 cd 01 00 .Ó..ýÒ..>é...Í..
20 d1 01 00 54 bb 01 00 6f eb 01 00 9a ba 01 00 Ñ..T»..oë..šº..
f3 ed 01 00 c6 f4 01 00 db 11 02 00 10 d5 01 00 óí..Æô..Û....Õ..
3f bb 01 00 90 be 01 00 cb d0 01 00 05 bf 01 00 ?»..¾..ËÐ...¿..
80 c7 01 00 37 ed 01 00 cf d1 01 00 2f da 01 00 €Ç..7í..ÏÑ../Ú..
f0 b2 01 00 62 ce 01 00 97 d9 01 00 9d dc 01 00 ð²..bÎ..—Ù..Ü..
1f e2 01 00 34 bb 01 00 bb cf 01 00 1a 08 02 00 .â..4»..»Ï......
25 b3 01 00 da e4 01 00 0e c1 01 00 61 d4 01 00 %³..Úä...Á..aÔ..
5c c4 01 00 59 c8 01 00 f2 e2 01 00 b5 e4 01 00 \Ä..YÈ..òâ..µä..
0d c0 01 00 7f e9 01 00 88 b9 01 00 b7 af 01 00 .À..é..ˆ¹..·¯..
f5 ea 01 00 f4 ce 01 00 ae d2 01 00 2a e9 01 00 õê..ôÎ..®Ò..*é..
77 cb 01 00 ef 94 01 00 18 b2 01 00 81 c0 01 00 wË..ï”...²..À..
89 9f 01 00 6c c3 01 00 e3 a2 01 00 3f dd 01 00 ‰Ÿ..lÃ..ã¢..?Ý..
bc cd 01 00 b7 b8 01 00 17 de 01 00 81 da 01 00 ¼Í..·¸...Þ..Ú..
c1 b1 01 00 8e c5 01 00 3c a0 01 00 5c df 01 00 Á±..ŽÅ..< ..\ß..
c7 c1 01 00 de b8 01 00 a4 d3 01 00 50 de 01 00 ÇÁ..Þ¸..¤Ó..PÞ..
f8 d7 01 00 0b a9 01 00 7f e1 01 00 12 d2 01 00 ø×...©..á...Ò..
98 ab 01 00 dc b3 01 00 18 d2 01 00 78 b9 01 00 ˜«..ܳ...Ò..x¹..
b9 cb 01 00 97 c0 01 00 e8 e3 01 00 76 cd 01 00 ¹Ë..—À..èã..vÍ..
85 f9 01 00 9e b0 01 00 d3 b6 01 00 a1 cc 01 00 …ù..ž°..Ó¶..¡Ì..
58 01 02 00 fd c2 01 00 2c d8 01 00 d0 db 01 00 X...ýÂ..,Ø..ÐÛ..
48 ad 01 00 04 ca 01 00 11 b9 01 00 e4 d5 01 00 H...Ê...¹..äÕ..
e2 be 01 00 fb b8 01 00 65 db 01 00 a1 bc 01 00 â¾..û¸..eÛ..¡¼..
bb bb 01 00 6e c8 01 00 45 0c 02 00 be c1 01 00 »»..nÈ..E...¾Á..
76 be 01 00 51 d3 01 00 40 cb 01 00 88 ce 01 00 v¾..QÓ..@Ë..ˆÎ..
82 c0 01 00 e4 8b 01 00 a3 a2 01 00 c7 b0 01 00 ‚À..ä‹..£¢..Ç°..
db c6 01 00 32 b8 01 00 ff 8b 01 00 ee b6 01 00 ÛÆ..2¸..ÿ‹..î¶..
1a c3 01 00 39 b8 01 00 3b b9 01 00 1c bc 01 00 .Ã..9¸..;¹...¼..
d4 cb 01 00 72 ad 01 00 67 e0 01 00 a7 ab 01 00 ÔË..r..gà..§«..
75 a6 01 00 26 d1 01 00 46 c3 01 00 1c a2 01 00 u¦..&Ñ..FÃ...¢..
1b d2 01 00 a7 b9 01 00 0c bd 01 00 0a be 01 00 .Ò..§¹...½...¾..
7b db 01 00 8c d7 01 00 3a d4 01 00 cd e2 01 00 {Û..Œ×..:Ô..Íâ..
af ea 01 00 55 d6 01 00 a1 d5 01 00 09 b4 01 00 ¯ê..UÖ..¡Õ...´..
bb 9c 01 00 be e2 01 00 58 d6 01 00 0e db 01 00 »œ..¾â..XÖ...Û..
94 ce 01 00 24 94 01 00 51 af 01 00 0d cd 01 00 ”Î..$”..Q¯...Í..
de e5 01 00 b1 b5 01 00 36 a7 01 00 f5 c7 01 00 Þå..±µ..6§..õÇ..
73 af 01 00 98 01 02 00 27 b4 01 00 8a d2 01 00 s¯..˜...'´..ŠÒ..
4e a3 01 00 6f ab 01 00 17 c1 01 00 14 f2 01 00 N£..o«...Á...ò..
72 04 02 00 4f a9 01 00 72 b7 01 00 73 b5 01 00 r...O©..r·..sµ..
6f b3 01 00 71 b4 01 00 8e b4 01 00 97 be 01 00 o³..q´..Ž´..—¾..
c6 c4 01 00 7f c0 01 00 b1 d1 01 00 d0 a3 01 00 ÆÄ..À..±Ñ..У..
3d b9 01 00 b4 90 01 00 39 b7 01 00 a7 b6 01 00 =¹..´..9·..§¶..
ad b6 01 00 be a6 01 00 4d b3 01 00 4f bd 01 00 ¶..¾¦..M³..O½..
82 9d 01 00 8d cb 01 00 84 b1 01 00 cd c3 01 00 ‚..Ë..„±..ÍÃ..
dc cd 01 00 b5 ad 01 00 80 a2 01 00 4e cf 01 00 ÜÍ..µ..€¢..NÏ..
c2 bf 01 00 55 b1 01 00 34 ba 01 00 8f b2 01 00 ¿..U±..4º..²..
14 db 01 00 ef cd 01 00 f9 da 01 00 84 c0 01 00 .Û..ïÍ..ùÚ..„À..
50 ba 01 00 14 cb 01 00 aa c6 01 00 f9 bd 01 00 Pº...Ë..ªÆ..ù½..
ae d6 01 00 b6 b4 01 00 e9 b3 01 00 29 cf 01 00 ®Ö..¶´..é³..)Ï..
01 a5 01 00 31 d7 01 00 c6 c5 01 00 ec bb 01 00 .¥..1×..ÆÅ..ì»..
73 09 02 00 0d d6 01 00 8e cf 01 00 7c db 01 00 s....Ö..ŽÏ..|Û..
6a bb 01 00 af f4 01 00 ac ca 01 00 6a ae 01 00 j»..¯ô..¬Ê..j®..
f9 b4 01 00 d5 9b 01 00 02 e8 01 00 81 b1 01 00 ù´..Õ›...è..±..
bd ac 01 00 9a d0 01 00 c7 d0 01 00 2d e7 01 00 ½¬..šÐ..ÇÐ..-ç..
d9 de 01 00 10 ad 01 00 0c bd 01 00 5a be 01 00 ÙÞ......½..Z¾..
74 e7 01 00 ab bf 01 00 25 cd 01 00 dc ac 01 00 tç..«¿..%Í..ܬ..
9d b4 01 00 c3 ad 01 00 e0 c4 01 00 ee bd 01 00 ´..Ã..àÄ..î½..
c0 c4 01 00 cc a7 01 00 7c c6 01 00 54 be 01 00 ÀÄ..̧..|Æ..T¾..
ab 1d 02 00 e2 fd 01 00 7e a0 01 00 02 13 02 00 «...âý..~ ......
80 a4 01 00 71 b0 01 00 83 c3 01 00 4b d6 01 00 €¤..q°..ƒÃ..KÖ..
7e ce 01 00 45 b4 01 00 e1 d9 01 00 59 b4 01 00 ~Î..E´..áÙ..Y´..
7e bc 01 00 83 c8 01 00 6a 9d 01 00 ef eb 01 00 ~¼..ƒÈ..j..ïë..
b8 f4 01 00 ab 1f 02 00 dc e9 01 00 5a cb 01 00 ¸ô..«...Üé..ZË..
9f c7 01 00 3a e2 01 00 e0 cb 01 00 6f a5 01 00 ŸÇ..:â..àË..o¥..
2d be 01 00 15 a9 01 00 87 c3 01 00 2d a8 01 00 -¾...©..‡Ã..-¨..
72 ca 01 00 ec cd 01 00 59 e7 01 00 5d bb 01 00 rÊ..ìÍ..Yç..]»..
b6 e1 01 00 23 b1 01 00 76 f3 01 00 79 c6 01 00 ¶á..#±..vó..yÆ..
db f6 01 00 b0 d8 01 00 25 dc 01 00 65 c2 01 00 Ûö..°Ø..%Ü..eÂ..
67 e3 01 00 7d b5 01 00 41 e6 01 00 2b c3 01 00 gã..}µ..Aæ..+Ã..
87 c4 01 00 1d 9f 01 00 2a a7 01 00 51 b7 01 00 ‡Ä...Ÿ..*§..Q·..
5b b1 01 00 3f ce 01 00 e6 c3 01 00 d5 e0 01 00 [±..?Î..æÃ..Õà..
b4 cd 01 00 80 dc 01 00 36 cd 01 00 be dd 01 00 ´Í..€Ü..6Í..¾Ý..
85 c8 01 00 76 dc 01 00 4c cd 01 00 63 d2 01 00 …È..vÜ..LÍ..cÒ..
f9 9f 01 00 5e 89 01 00 09 e7 01 00 cd ea 01 00 ùŸ..^‰...ç..Íê..
a1 9f 01 00 26 bb 01 00 97 c8 01 00 e9 bf 01 00 ¡Ÿ..&»..—È..é¿..
eb de 01 00 6e b4 01 00 d4 06 02 00 43 e2 01 00 ëÞ..n´..Ô...Câ..
99 cb 01 00 83 e2 01 00 d1 d8 01 00 f4 b2 01 00 ™Ë..ƒâ..ÑØ..ô²..
33 d6 01 00 fc b1 01 00 41 ce 01 00 1e b2 01 00 3Ö..ü±..AÎ...²..
ff db 01 00 cc d4 01 00 4a b4 01 00 89 9d 01 00 ÿÛ..ÌÔ..J´..‰..
c4 ee 01 00 d0 c6 01 00 75 d3 01 00 cb cf 01 00 Äî..ÐÆ..uÓ..ËÏ..
b9 ef 01 00 06 b6 01 00 86 d5 01 00 c3 ac 01 00 ¹ï...¶..†Õ..ì..
e1 f7 01 00 cb af 01 00 a0 d5 01 00 ad d7 01 00 á÷..˯.. Õ..×..
22 c7 01 00 e3 ae 01 00 7b 89 01 00 c6 c1 01 00 "Ç..ã®..{‰..ÆÁ..
75 e5 01 00 cc b6 01 00 77 e4 01 00 20 b1 01 00 uå..̶..wä.. ±..
bb c4 01 00 8f bf 01 00 e4 ce 01 00 d4 b2 01 00 »Ä..¿..äÎ..Ô²..
6a b6 01 00 5e bc 01 00 b8 cb 01 00 75 c5 01 00 j¶..^¼..¸Ë..uÅ..
57 a0 01 00 19 aa 01 00 93 e8 01 00 30 a4 01 00 W ...ª..“è..0¤..
e9 c2 01 00 8a d4 01 00 4a b4 01 00 03 b9 01 00 éÂ..ŠÔ..J´...¹..
20 ae 01 00 6f c7 01 00 49 b8 01 00 30 b9 01 00 ®..oÇ..I¸..0¹..
7b c1 01 00 1b c2 01 00 6f c6 01 00 b8 9e 01 00 {Á...Â..oÆ..¸ž..
0c af 01 00 94 a0 01 00 cf d5 01 00 9a dd 01 00 .¯..” ..ÏÕ..šÝ..
6f 9a 01 00 bc cf 01 00 30 ab 01 00 03 d7 01 00 oš..¼Ï..0«...×..
56 db 01 00 e8 b9 01 00 03 b3 01 00 58 ec 01 00 VÛ..è¹...³..Xì..
98 f7 01 00 95 ca 01 00 e2 f1 01 00 6e d4 01 00 ˜÷..•Ê..âñ..nÔ..
0f b7 01 00 b5 c9 01 00 bd d2 01 00 1e e0 01 00 .·..µÉ..½Ò...à..
ee da 01 00 4c 97 01 00 7a a7 01 00 01 be 01 00 îÚ..L—..z§...¾..
55 c4 01 00 ac 86 01 00 25 ab 01 00 4a a3 01 00 UÄ..¬†..%«..J£..
8c c2 01 00 92 c6 01 00 33 af 01 00 64 f7 01 00 ŒÂ..’Æ..3¯..d÷..
cf b9 01 00 c7 bc 01 00 62 c7 01 00 a5 d3 01 00 Ϲ..Ǽ..bÇ..¥Ó..
cd b9 01 00 48 a4 01 00 0f c6 01 00 6a b2 01 00 ͹..H¤...Æ..j²..
74 9e 01 00 f4 c2 01 00 5d fe 01 00 92 ce 01 00 tž..ôÂ..]þ..’Î..
4c dc 01 00 6b de 01 00 0c cb 01 00 9a d9 01 00 LÜ..kÞ...Ë..šÙ..
4f e7 01 00 9d ae 01 00 89 c5 01 00 80 a6 01 00 Oç..®..‰Å..€¦..
61 bb 01 00 02 d0 01 00 a8 ad 01 00 a6 ba 01 00 a»...Ð..¨..¦º..
0a a2 01 00 b0 88 01 00 e2 b2 01 00 45 cc 01 00 .¢..°ˆ..â²..EÌ..
06 d6 01 00 ed bd 01 00 1c c8 01 00 8a b8 01 00 .Ö..í½...È..Š¸..
e6 c7 01 00 67 cc 01 00 d0 ed 01 00 92 d1 01 00 æÇ..gÌ..Ðí..’Ñ..
53 d5 01 00 fd b2 01 00 3a b1 01 00 3e a1 01 00 SÕ..ý²..:±..>¡..
3f ba 01 00 3a b1 01 00 fe cc 01 00 a9 9e 01 00 ?º..:±..þÌ..©ž..
54 e2 01 00 54 96 01 00 11 bc 01 00 5a ba 01 00 Tâ..T–...¼..Zº..
1b f5 01 00 d8 d5 01 00 32 96 01 00 1a 94 01 00 .õ..ØÕ..2–...”..
d1 c6 01 00 c4 b9 01 00 0a a5 01 00 30 c8 01 00 ÑÆ..Ĺ...¥..0È..
9f bc 01 00 0b d5 01 00 be b9 01 00 e3 90 01 00 Ÿ¼...Õ..¾¹..ã..
4a b6 01 00 9f 9e 01 00 89 e5 01 00 23 a2 01 00 J¶..Ÿž..‰å..#¢..
cf 9d 01 00 bc 9f 01 00 da 9a 01 00 79 9d 01 00 Ï..¼Ÿ..Úš..y..
16 dd 01 00 ff a0 01 00 1a af 01 00 7a c3 01 00 .Ý..ÿ ...¯..zÃ..
d6 98 01 00 1f c7 01 00 6e b7 01 00 9c 96 01 00 Ö˜...Ç..n·..œ–..
cf c4 01 00 f7 fa 01 00 23 a5 01 00 1b b9 01 00 ÏÄ..÷ú..#¥...¹..
4b b3 01 00 75 af 01 00 d0 79 01 00 fb c9 01 00 K³..u¯..Ðy..ûÉ..
89 cc 01 00 e5 a0 01 00 80 c1 01 00 26 a7 01 00 ‰Ì..å ..€Á..&§..
eb bb 01 00 71 b4 01 00 d2 96 01 00 39 ca 01 00 ë»..q´..Ò–..9Ê..
01 b4 01 00 88 ba 01 00 68 8b 01 00 d5 ab 01 00 .´..ˆº..h‹..Õ«..
36 ae 01 00 46 a0 01 00 4b 9d 01 00 3f a4 01 00 6®..F ..K..?¤..
79 cf 01 00 a0 ce 01 00 0f ac 01 00 3c b2 01 00 yÏ.. Î...¬..<²..
35 af 01 00 8a 97 01 00 18 8d 01 00 d7 b5 01 00 5¯..Š—.....×µ..
5a ab 01 00 84 b7 01 00 51 ee 01 00 ee 95 01 00 Z«..„·..Qî..î•..
1f bd 01 00 da c3 01 00 dd b9 01 00 a4 c1 01 00 .½..ÚÃ..ݹ..¤Á..
8b cd 01 00 48 c0 01 00 18 b6 01 00 af a6 01 00 ‹Í..HÀ...¶..¯¦..
ed a0 01 00 cf 98 01 00 a9 d0 01 00 e0 92 01 00 í ..Ϙ..©Ð..à’..
5a 0f 02 00 e5 8f 01 00 6d 9a 01 00 bf cf 01 00 Z...å..mš..¿Ï..
73 b2 01 00 3f 7e 01 00 47 99 01 00 43 97 01 00 s²..?~..G™..C—..
11 c8 01 00 f6 8f 01 00 7d a7 01 00 db ad 01 00 .È..ö..}§..Û..
ee 99 01 00 0b a7 01 00 02 a1 01 00 7e 9d 01 00 î™...§...¡..~..
91 a9 01 00 db cd 01 00 d2 9d 01 00 23 b7 01 00 ‘©..ÛÍ..Ò..#·..
20 af 01 00 a6 b6 01 00 b4 d3 01 00 75 b5 01 00 ¯..¦¶..´Ó..uµ..
a2 8a 01 00 cd f6 01 00 e2 c8 01 00 25 a0 01 00 ¢Š..Íö..âÈ..% ..
9d c1 01 00 0d cb 01 00 e4 86 01 00 d6 9a 01 00 Á...Ë..ä†..Öš..
72 cf 01 00 ea c5 01 00 1c b1 01 00 b3 f3 01 00 rÏ..êÅ...±..³ó..
a6 c4 01 00 22 b4 01 00 89 b2 01 00 f3 c4 01 00 ¦Ä.."´..‰²..óÄ..
cd b4 01 00 ad bc 01 00 b6 a2 01 00 07 a3 01 00 Í´..¼..¶¢...£..
02 c8 01 00 c3 a9 01 00 eb a2 01 00 e5 bc 01 00 .È..é..ë¢..å¼..
9c dc 01 00 0b 94 01 00 97 a5 01 00 1f 8f 01 00 œÜ...”..—¥.....
7c a5 01 00 11 a2 01 00 0c b3 01 00 7c b2 01 00 |¥...¢...³..|²..
73 9a 01 00 5e 98 01 00 ec 97 01 00 9c ea 01 00 sš..^˜..ì—..œê..
7c ef 01 00 90 89 01 00 9c c7 01 00 ca 28 03 00 |ï..‰..œÇ..Ê(..
33 db 01 00 1b bb 01 00 86 df 01 00 8d b3 01 00 3Û...»..†ß..³..
53 9f 01 00 d6 ca 01 00 65 a9 01 00 d0 89 01 00 SŸ..ÖÊ..e©..Љ..
0d cf 01 00 90 a7 01 00 0d dc 01 00 c2 cb 01 00 .Ï..§...Ü..ÂË..
41 ae 01 00 9e a8 01 00 a0 96 01 00 17 91 01 00 A®..ž¨.. –...‘..
b2 22 02 00 87 a5 01 00 29 a2 01 00 1d af 01 00 ²"..‡¥..)¢...¯..
80 c5 01 00 26 9f 01 00 02 b3 01 00 0a d4 01 00 €Å..&Ÿ...³...Ô..
(cut because the message reaches beyond allowable length and won't send if I didn't cut)
