Hey guys,
I am working on a project using PIC18f4620 in MPLAB X 3.30 using XC8 compiler. I have compiled the code and found no errors in the program, I have simulated it in MPLAB and it works there but I am not able to run it on Hardware, I also tested the hardware using the same micro with a working Hex file and it works. I am not sure what I am doing wrong.
Thank you for your help.
Regards,
YashRK.
* File: main.c
* Author: YASH
* Created on June 7, 2016, 4:00 PM
#include <xc.h>
#include <P18F4620.h>
#include <stdlib.h>
#include <stdio.h>
// CONFIG1H
#pragma config OSC = HSPLL // Oscillator Selection bits (HS oscillator, PLL enabled (Clock Frequency = 4 x FOSC1))
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = SBORDIS // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3 // Brown Out Reset Voltage bits (Minimum setting)
// CONFIG2H
#pragma config WDT = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-003FFFh) not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (004000-007FFFh) not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (008000-00BFFFh) not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (00C000-00FFFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-003FFFh) not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (004000-007FFFh) not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (008000-00BFFFh) not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (00C000-00FFFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
//#include<P18F4620.h>
#include <string.h>
#define data PORTB
#define rs PORTDbits.RD6
#define en PORTDbits.RD7
#define _XTAL_FREQ 40000000
void delay(void);
void lcddata(unsigned char value);
void lcdcmd(unsigned char value);
void lcd_init();
void Lcd_Set_Cursor(char a, char b);
void lcd_data_string(char *a, unsigned int b);
void Lcd_Shift_Right();
void Lcd_Shift_Left();
void lcd_num(unsigned int a);
char dis1[] ="ABC";
char dis2[] ="India";
void main(){
TRISB =0x00; // lcd 0-7
TRISD =0x00; // D6, D7
delay();
lcd_init();
delay();
// Lcd_Set_Cursor(1,7);
// delay();
// lcd_data_string(dis1,3);
// delay();
// Lcd_Set_Cursor(2,6);
// delay();
// lcd_data_string(dis2,5);
// for(int i=0; i<1000; i++){
// lcdcmd(0x01);
// __delay_ms(10);
// Lcd_Set_Cursor(1,1);
// __delay_ms(10);
// lcd_num(i);
// __delay_ms(10);
// delay();
while(1){
delay();
lcddata('A');
delay();
delay();
void lcd_init(){
en = 0;
for(int i =0; i<25; i++)__delay_ms(10);
lcdcmd(0x38);
// lcdcmd(0x38);
// delay();
// lcdcmd(0x38);
// delay();
lcdcmd(0x0C); //display on cursor off
delay();
lcdcmd(0x01); //clear LCD
delay();
lcdcmd(0x06);
delay();
lcdcmd(0x02); //shift cursor right
delay();
void Lcd_Set_Cursor(char a, char b){ //row, colum
char temp;
if(a == 1){
temp = 0x80 + b - 1;
lcdcmd(temp);
else if(a == 2)
temp = 0xC0 + b - 1;
lcdcmd(temp);
delay();
void lcdcmd(unsigned char value){
data = value;
rs =0;
en =1;
__delay_us(1);
en =0;
void lcddata(unsigned char value){
data = value;
rs =1;
en =1;
__delay_us(1);
en =0;
void delay(void) {
__delay_ms(15);
void lcd_data_string(char *a, unsigned int b){ //(array, length)
int i;
for(i=0;i<b;i++){
lcddata(a[i]);
__delay_ms(2);
void Lcd_Shift_Right(){
lcdcmd(0x01);
lcdcmd(0x0C);
void Lcd_Shift_Left(){
lcdcmd(0x01);
lcdcmd(0x08);
void lcd_num(unsigned int a){ //integer to be printed
char buf[10];
itoa(buf, a, 10);
lcd_data_string(buf,5);
