Author Topic: Stellaris Launchpad Logic Analyser  (Read 4977 times)
Offline HackedFridgeMagnetTopic starter
« on: March 13, 2013, 05:46:54 am »
As somebody pointed out, a logic analyser might be a good use for your Stellaris Launchpad.
So I gave it a go.
http://www.fischl.de/arm/sllogiclogger_logic_analyser_for_stellaris_launchpad/
the protocol is I2C talking to a ds1307
So the analysis doesn't quite work yet, but my data seems to be coming in albeit with some ugly spikes.
And I have remote debugging on the launch pad if I needed it.
My bus pirate decodes the same data ok so I am not sure what is going on.
One day I will look a bit deeper.
« Last Edit: March 13, 2013, 05:53:20 am by HackedFridgeMagnet »
Offline ve7xen
    • VE7XEN Blog
Re: Stellaris Launchpad Logic Analyser
« Reply #1 on: March 13, 2013, 05:53:26 am »
Looks like the decoder has detected SCL/SDA incorrectly, you'll probably need to set those manually.
73 de VE7XEN
He/Him
« Reply #2 on: March 13, 2013, 06:28:40 am »
Yes that was the case, I turned off auto detect,  and I have less errors.
Offline Skimask
« Reply #3 on: March 13, 2013, 07:17:28 am »
WOW!  Great find!  And just when I was wanting one...
I've got 3 of these Launchpad's sitting here at the bench waiting for an application like this.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline BravoV
  • +++ ATH1
« Reply #4 on: March 13, 2013, 07:20:10 am »
Its about time my launchpad to be loaded with decent app rather than noob apps all this time.  :-DD
Thanks !  :-+
Offline Skimask
« Reply #5 on: March 13, 2013, 01:54:23 pm »
I resemble that remark!  :-//
I turned it on.
Offline ve7xen
    • VE7XEN Blog
« Reply #6 on: March 13, 2013, 06:04:59 pm »
Seem to correspond with the glitches on your SDA line. They look like legit errors to me.
73 de VE7XEN
He/Him
Offline bingo600
« Reply #7 on: March 14, 2013, 09:48:43 pm »
Guilty as charged  ::)
/Bingo
