Author Topic: PIC32 external osc help  (Read 1074 times)
Offline mapexmbirchTopic starter
« on: March 22, 2017, 04:50:19 pm »
Hi
I have a PIC32MZ1024EF064 with a 8MHz external resonator.
http://onecall.farnell.com/murata/cstce8m00g52a-r0/resonator-ceramic-8mhz-smd/dp/2443267?ost=CSTCE8M00G52A-R0&selectedCategoryId=&categoryNameResp=All&searchView=table&iscrfnonsku=false
I have used this resonator before on a PIC18 and PIC24, both worked fine.
I can get my code to work fine with the internal FRC (8MHz), but when I switch it to the external osc, it doesn't start and it uses the other internal osc.
My setup code:
#pragma config FMIIEN = ON             // Ethernet RMII/MII Enable (MII Enabled)
#pragma config FETHIO = ON              // Ethernet I/O Pin Select (Default Ethernet I/O)
#pragma config PGL1WAY = ON            // Permission Group Lock One Way Configuration (Allow only one reconfiguration)
#pragma config PMDL1WAY = ON            // Peripheral Module Disable Configuration (Allow only one reconfiguration)
#pragma config IOL1WAY = ON             // Peripheral Pin Select Configuration (Allow only one reconfiguration)
#pragma config FUSBIDIO = OFF           // USB USBID Selection (Controlled by the USB Module)
// DEVCFG2
#pragma config FPLLIDIV = DIV_1         // System PLL Input Divider (1x Divider)
#pragma config FPLLRNG = RANGE_5_10_MHZ // System PLL Input Range (8-16 MHz Input)
#pragma config FPLLICLK = PLL_POSC     // System PLL Input Clock Selection (POSC is input to the System PLL)
#pragma config FPLLMULT = MUL_45         // System FRC Multiplier (FRC Multiply by 45)
#pragma config FPLLODIV = DIV_2         // System PLL Output Clock Divider (2x Divider)
#pragma config UPLLFSEL = FREQ_12MHZ    // USB PLL Input Frequency Selection (USB PLL input is 12 MHz)
// DEVCFG1
#pragma config FNOSC = SPLL          // Oscillator Selection Bits (Primary Osc (HS,EC))
#pragma config DMTINTV = WIN_127_128    // DMT Count Window Interval (Window/Interval value is 127/128 counter value)
#pragma config FSOSCEN = OFF            // Secondary Oscillator Enable (Disable SOSC)
#pragma config IESO = OFF                // Internal/External Switch Over (Disabled)
#pragma config POSCMOD = HS             // Primary Oscillator Configuration (HS osc mode)
#pragma config OSCIOFNC = OFF           // CLKO Output Signal Active on the OSCO Pin (Disabled)
#pragma config FCKSM = CSDCMD           // Clock Switching and Monitor Selection (Clock Switch Enabled, FSCM Enabled)
#pragma config WDTPS = PS1048576        // Watchdog Timer Postscaler (1:1048576)
#pragma config WDTSPGM = STOP           // Watchdog Timer Stop During Flash Programming (WDT stops during Flash programming)
#pragma config WINDIS = NORMAL          // Watchdog Timer Window Mode (Watchdog Timer is in non-Window mode)
#pragma config FWDTEN = OFF             // Watchdog Timer Enable (WDT Disabled)
#pragma config FWDTWINSZ = WINSZ_25     // Watchdog Timer Window Size (Window size is 25%)
#pragma config DMTCNT = DMT31           // Deadman Timer Count Selection (2^31 (2147483648))
#pragma config FDMTEN = OFF             // Deadman Timer Enable (Deadman Timer is disabled)
// DEVCFG0
#pragma config DEBUG = OFF              // Background Debugger Enable (Debugger is disabled)
#pragma config JTAGEN = OFF             // JTAG Enable (JTAG Disabled)
#pragma config ICESEL = ICS_PGx1        // ICE/ICD Comm Channel Select (Communicate on PGEC1/PGED1)
#pragma config TRCEN = ON               // Trace Enable (Trace features in the CPU are enabled)
#pragma config BOOTISA = MIPS32         // Boot ISA Selection (Boot code and Exception code is MIPS32)
#pragma config FECCCON = OFF_UNLOCKED   // Dynamic Flash ECC Configuration (ECC and Dynamic ECC are disabled (ECCCON bits are writable))
#pragma config FSLEEP = OFF             // Flash Sleep Mode (Flash is powered down when the device is in Sleep mode)
#pragma config DBGPER = PG_ALL          // Debug Mode CPU Access Permission (Allow CPU access to all permission regions)
#pragma config SMCLR = MCLR_NORM        // Soft Master Clear Enable bit (MCLR pin generates a normal system Reset)
#pragma config SOSCGAIN = GAIN_2X       // Secondary Oscillator Gain Control bits (2x gain setting)
#pragma config SOSCBOOST = OFF          // Secondary Oscillator Boost Kick Start Enable bit (Normal start of the oscillator)
#pragma config POSCGAIN = GAIN_2X       // Primary Oscillator Gain Control bits (2x gain setting)
#pragma config POSCBOOST = ON           // Primary Oscillator Boost Kick Start Enable bit (Boost the kick start of the oscillator)
#pragma config EJTAGBEN = NORMAL        // EJTAG Boot (Normal EJTAG functionality)
I have no idea what you should look for when selecting an resonator.
When I probe the pins there is about 0.5V of DC on one pin and 0V on the other.   A picture of how I connected it to the PIC is attached.
Any help would be greatly appreciated!
Offline Lunasix
Re: PIC32 external osc help
« Reply #1 on: March 22, 2017, 05:01:23 pm »
Read the errata !
