Author Topic: pin mapping on dsPIC33F  (Read 3064 times)
Offline NiHaoMikeTopic starter
    • Facebook Page
« on: September 27, 2011, 07:45:50 pm »
On the dsPIC33F, is it possible to map a pin to be an output of one module (output compare) and an input of another module (timer) at the same time? I'm trying to derive two synchronized clocks for a data acquisition circuit, one of which is the master clock of the ADCs and the other commands a conversion. The second clock is about 1/20th or so the frequency of the first, synchronized such that its falling edge happens when the first clock is low.
Offline johnmx
  • Country: pt
Re: pin mapping on dsPIC33F
« Reply #1 on: September 27, 2011, 11:02:06 pm »
Yes it is.
Best regards,
johnmx
