Author Topic: PMS150 PWM generator  (Read 330 times)
Offline itelite
« on: August 15, 2019, 09:36:44 pm »
Fellow Nerds.  Trying out the PMS150 and more than a bit lost in this language and IDE. Hoping someone can point me in the right direction.
Goal: Fixed frequency PWM output with duty based on the state of 2 pins. high or low state.
I see that there is demo code that looks like it does this but it does not compile when you switch the chip to PMS150.  It gives some errors that i simply do not know what they mean, and what the remediation would be.
Also in the manual/help it states there is a PWM module under "generate code" and at least for that module is missing.
Code:
#include   "extern.h"
BYTE   pwm_duty;   //   Modify pwm_duty, then FPPA change the PWM duty
void   FPPA0 (void)
   .ADJUST_IC   8MIPS      // IHRC/2 = 8MIPS, WatchDog Disable, RAM 0,1 temporary be used
   pwm_duty   =   0;
   pmode   Program_Mode;         //   if has more FPPAs than 2
   fppen   =   0xFF;
   BIT      Sync   :   PA.0;
   BIT      f_Duty_Dn;
   $ Sync   Out, Low;
   while (1)
      WORD   count   =   0x5678;   //   Only for delay
      while (1)
         $ Sync   Tog;
         .delay   PWM_CYCLE - 5;
         count--;
         if (CF)   break;
      nop
      $ Sync   Tog;
      if (! f_Duty_Dn)
         if (pwm_duty >= PWM_CYCLE)
            f_Duty_Dn   =   1;
            pwm_duty--;
         else
            pwm_duty++;
      else
         if (! pwm_duty)
            f_Duty_Dn   =   0;
            pwm_duty++;
         else
            nop
            pwm_duty--;
      .delay   PWM_CYCLE - 13;
Errors:
C:\PADAUK_Tool\0.87\Demo\PWM\PWM.C(8): Syntax error happen !!!
C:\PADAUK_Tool\0.87\Demo\PWM\PWM.C(12): Syntax error : 'pmode'
C:\PADAUK_Tool\0.87\Demo\PWM\PWM.C(14): Syntax error : 'fppen'
C:\PADAUK_Tool\0.87\Demo\PWM\PWM.C(26): The 'TOG' not be supported at Assembly
C:\PADAUK_Tool\0.87\Demo\PWM\PWM.C(32): The 'TOG' not be supported at Assembly
pmode seems to be related to running multiple differnt FPPA, and i can comment it out.
fppen seems to be the default choice of those to run.  i can comment it out.
Syntax error happen, i just have no idea.
TOG no idea.
If there is an other way to do this i am all ears of course. I thought i would start with the demo code to see what happens.
