Hello !
We have application allready in production running on a STM32F469Bit6.
Now we port it to a gigadevice gd32f450zk mcu.
We experience problems with the c++ application code which goes to hard faults at "random" positions on the gd32 mcu.
The hal (hardwareabstraction layer) is running and clock, sdram, ext flash, controller area network, lcd and trace is working
We checked the timing on a analog output with the oscilloscope, checked the pin connections with the miroscope and used two different boards. a hardware error is unlikely.
we have testprograms for doing all sdram and iram checks, allready went back to the slowest timing possible and checked the connections on the (homemade) board -
everything seems ok and c code is running without such problems.
heap is properly mapped, allocate and new operator return valid pointers.
iram is also working of course. some code runs from the extflash but we also checked this with a test application:
no errors detected here and additionally c++ code may still produce hard faults when linked to iram.
malloc and new is all we use in the c++ code where allready the
hard faults occur.
(No initialization of external interrupts or peripherals)
the c++ application code goes to a hard fault sporadically at different programm position that happens during predictable initialization where no asychnronous external events occur, no interrupts are enabled - just allocating and initializing straight forward.
rebuilding the app with a stripped down object oriented model could not reproduce the errors till now.
we're a bit clueless at the moment and we hope it's our fault but we can not figure out what we do wrong...
The hard fault status register
states a bus data error but the error only occurs within the c++ application and not if we test the rams with test routines. (see attachment)
- IMPRECISERR is set when a data bus error has occurred, but the return address in the stack frame is not related to the instruction that caused the error.
- FORCED is set to indicate a forced HardFault, generated by escalation of a fault with configurable priority that cannot be handled, either because of priority or because it is disabled
see
https://www.keil.com/dd/vtr/4889/8687.htmanyone faced such issues with c++ on gigadevice on keil environment?
kind regards + hello to the forum members!
PS: The hardfault code is (see attachment)
The ADDR is always different, like mentioned above.
We're on the latest 2.0.0 device support package
compiler version 1.6.3 also up to date.
still keil 5.18a is a bit out of date.
