As the title says, I am having issues burning the bootloader to a 328PB chip. Breadboard setup using a clamshell. I am using Minicore that has support for the 328PB and this setup has worked in the past, I have burned the bootloader to close to 100 328PB chips using this setup. I checked and it still works with the 328P chip.
Here is the output from the IDE
"C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude" "-CC:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/avrdude.conf" -v -patmega328pb -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:0b11110101:m -Uhfuse:w:0xd7:m -Ulfuse:w:0b11111111:m
avrdude: Version 7.2-arduino.1
Copyright the AVRDUDE authors;
see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1\avrdude.conf
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328PB
Chip Erase delay : 10500 us
PAGEL : PD7
BS2 : PC2
RESET disposition : possible i/o
RETRY pulse : SCK
Serial program mode : yes
Parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0x00 0x00
flash 65 10 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
avrdude: device signature = 0x1e9516 (probably m328pb)
avrdude: erasing chip
avrdude: processing -U lock:w:0xff:m
avrdude: reading input file 0xff for lock
with 1 byte in 1 section within [0, 0]
avrdude: writing 1 byte lock ...
avrdude: 1 byte of lock written
avrdude: verifying lock memory against 0xff
avrdude: 1 byte of lock verified
avrdude: processing -U efuse:w:0b11110101:m
avrdude: reading input file 0b11110101 for efuse
avrdude: writing 1 byte efuse ...
avrdude: 1 byte of efuse written
avrdude: verifying efuse memory against 0b11110101
avrdude: 1 byte of efuse verified
avrdude: processing -U hfuse:w:0xd7:m
avrdude: reading input file 0xd7 for hfuse
avrdude: writing 1 byte hfuse ...
"C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude" "-CC:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/avrdude.conf" -v -patmega328pb -cstk500v1 -PCOM7 -b19200 "-Uflash:w:C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart1_rxb4_txb3/led+b5/urboot_atmega328pb_pr_ee_ce.hex:i" -Ulock:w:0xff:m
avrdude: 1 byte of hfuse written
avrdude: verifying hfuse memory against 0xd7
avrdude: 1 byte of hfuse verified
avrdude: processing -U lfuse:w:0b11111111:m
avrdude: reading input file 0b11111111 for lfuse
avrdude: writing 1 byte lfuse ...
avrdude: 1 byte of lfuse written
avrdude: verifying lfuse memory against 0b11111111
avrdude: 1 byte of lfuse verified
avrdude done. Thank you.
Using Port : COM7
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Note: flash memory has been specified, an erase cycle will be performed.
To disable this feature, specify the -D option.
avrdude: processing -U flash:w:C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart1_rxb4_txb3/led+b5/urboot_atmega328pb_pr_ee_ce.hex:i
avrdude: reading input file C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart1_rxb4_txb3/led+b5/urboot_atmega328pb_pr_ee_ce.hex for flash
with 368 bytes in 2 sections within [0x7e80, 0x7fff]
using 3 pages and 16 pad bytes
avrdude: writing 368 bytes flash ...
Writing | ################################################## | 100% 0.08s
avrdude: 368 bytes of flash written
avrdude: verifying flash memory against C:\Users\Andrew\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.1/bootloaders/urboot/atmega328pb/watchdog_1_s/autobaud/uart1_rxb4_txb3/led+b5/urboot_atmega328pb_pr_ee_ce.hex
Reading | ################################################## | 100% 0.00s
avrdude avr_verify() warning: verification mismatch
device 0x40 != input 0x11 at addr 0x7e80 (error)
device 0x40 != input 0x24 at addr 0x7e81 (error)
device 0x41 != input 0x24 at addr 0x7e82 (error)
device 0x41 != input 0xb6 at addr 0x7e83 (error)
device 0x42 != input 0x14 at addr 0x7e84 (error)
device 0x42 != input 0xbe at addr 0x7e85 (error)
device 0x43 != input 0x80 at addr 0x7e86 (error)
device 0x43 != input 0xe0 at addr 0x7e87 (error)
device 0x44 != input 0x7e at addr 0x7e88 (error)
device 0x44 != input 0xd0 at addr 0x7e89 (error)
suppressing further verification errors
avrdude do_op() error: verification mismatch
Failed to burn bootloader: uploading error: exit status 1
Any help would be appreciated, I've already spent about 6 hours on this going through connections and banging my head against the wall. I have tried powering from 5V supply as well as the Arduino programmer. I am using Arduino as a programmer, I have tried clone Nano's, real Nano, and a real Uno R3. Same error.
