I want to read the temperature data from the DHT11 sensor connected to the Pico using RS485 between Raspberry Pi 4 and Raspberry Pi Pico. I use the following code for this, but when I use it like this, I can send data from Raspberry Pi without any problems. However, when I send data from Raspberry Pi Pico, if I assume the temperature is 25, sometimes I can read this value from Raspberry Pi and sometimes I can't. I tried to adjust the correct time with Time.sleep() but I couldn't succeed. How can I solve this?
Raspberry Pi Code
import serial
import time
RS485 = serial.Serial('/dev/serial0', baudrate=9600, timeout=1)
def send_data(data):
ser = serial.Serial('/dev/serial0', baudrate=9600, timeout=1)
ser.write(data.encode())
print("data sent")
temperature = 0
while True:
data_to_send = "xtemperature"
time.sleep(1)
send_data(data_to_send)
time.sleep(1)
while True:
received_data = RS485.readline().rstrip()
received_data = received_data.decode('utf-8')
print(received_data)
time.sleep(1)
received_value = int(received_data)
if 0 <= received_value <= 70:
temperature=received_value
break
break
print("TEMPERATURE : ",temperature)
Raspberry Pico Code
from machine import Pin
import time
from dht import DHT11
uart_tx = machine.Pin(4) # TX pin: GPIO 0
uart_rx = machine.Pin(5) # RX pin: GPIO 1
# UART nesnesi oluşturma
uart = machine.UART(1, baudrate=9600, tx=uart_tx, rx=uart_rx)
def response():
received_data = uart.read()
try:
received_string = received_data.decode('utf-8').strip()
print("DATA :")
print(received_string)
if received_string:
if received_string[0] == 'x':
pin = Pin(15,Pin.IN,Pin.PULL_UP)
d = DHT11(Pin(15))
d.measure()
T = d.temperature()
x=0
while x<150:
x=x+1
T=d.temperature()
send_data = str(T)
data = (send_data + "\r\n")
time.sleep(1)
uart.write(data.encode('utf-8'))
print("data sent")
print(data)
return received_string
except UnicodeError:
pass
return ""
while True:
if uart.any():
incoming_data = response()
print(incoming_data)
