Author Topic: raspberry pi shield  (Read 1930 times)
Offline Munyua44Topic starter
  • Country: ke
raspberry pi shield
« on: January 15, 2022, 06:27:26 am »
Hello all, am working on a project that involves the raspberry pi and 9i don't want to purchase it. Am current l am working on the raspberry pi shield like this one here
https://www.pcbway.com/project/shareproject/RaspberryPi_IO_Shield_v1_0_EA_03055437.html
Am new to this and am confused on which microcontrollers or chips i should use. Please! advice me
Offline luiHS
Re: raspberry pi shield
« Reply #1 on: January 16, 2022, 05:45:15 pm »
Why don't you want to use a Raspberry ?
You already have the design done, and it's cheap. If you put a Raspberry pi zero2 in there, you won't be able to get it cheaper using a microcontroller and you'll have to create your own PCB.
The requirements to use a microcontroller, instead of a Raspberry, are simply that it has I2C, UART and 10 GPIO ports. Pretty much any 32 bit microcontroller will do.
The problem is that right now almost everything is out of stock, due to the global semiconductor crisis. You could still find in stock some LPC or i.Mx from NXP, also some STM32 from ST.
The following users thanked this post: Munyua44
