Author Topic: Problems with STM32 PMSM FOC SDK  (Read 169294 times)
Offline psyke
  • Country: ar
Re: Problems with STM32 PMSM FOC SDK
« Reply #350 on: November 06, 2019, 02:09:44 pm »
Thank you for answering guys.
I'd first verify both ppr and counting direction of the encoder. You can also use one of the DAC outputs to monitor the electrical angle along with one of the phase voltages, while spinning the motor manually. If these stay in sync after a few revolutions then you can tick that off. Regarding the encoder I channel: in earlier versions that's something that you have to code by yourself - set up an interrupt for that signal in your MCU and let the ISR manually set the correct offset (to be measured once).
Ok, going to try the DAC output when I get close to an oscilloscope. Regarding to the encoder I channel, the motor should work anyways even if I dont implement the interrupt for that channel?
Thing that you need to do the "encoder align" first and only then you mus click on "start motor".
Have you tried this?
If you never align the encoder, the control stage will know where the rotor is and will probably get stuck.
PS: In these new versions I don't know if the "start motor" already makes the encoder alignment, but it makes no sense to me.
In new versions, if you click "Start motor" for the first time, it does an encoder alignment, and after that, it starts the motor. Successive "Start motor" commands just start the motor without alignment, as it is already aligned.
I already tried hitting encoder alignment before starting, I think I tried everything available in the library  |O
I also got inside the code of the library, trying to know why it doesn't spin the motor... but got no success finding the problem.
« Last Edit: November 06, 2019, 02:13:02 pm by psyke »
Offline Dave_PTTopic starter
  • Country: pt
    • DavidMartinsEngineering
« Reply #351 on: November 06, 2019, 03:56:02 pm »
Stupid question: the phases order, number of pole pairs, etc are correct, right?
You can run the motor in sensorless mode, so all parameters must be correct, but you never know ...  :-//
Offline psyke
  • Country: ar
« Reply #352 on: November 06, 2019, 04:18:56 pm »
I measured number of pole pairs with ST’s method, energizing 2 phases and counting the amount of snaps in a single revolution
I tried changing two phases order with no success, it does the same
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #353 on: November 06, 2019, 06:19:22 pm »
I'd say that having one is a must when developing a motor controller. When having a problem, I first hook that up. I only start debugging the code when it doesn't look like an electrical problem.
The I channel based alignment is a substitute for the software alignment that the library does. If your application is fine with the motor being 'hard' turned each time the system powers up, and you can guarantee that there is no shaft torque during this time, then you don't need that.
We Are The Watt - Resistance Is Futile!
The following users thanked this post: Dave_PT
Offline psyke
  • Country: ar
« Reply #354 on: November 06, 2019, 07:01:13 pm »
Ok, so the I channel isn't going to be used for now. First I need to make the motor spin with encoder.
Regarding to the oscilloscope, we have some for students use in the university. I know its very important to have one, but I don't.
Maybe tomorrow I can go use one of those. I will post updates after that
Offline psyke
  • Country: ar
« Reply #355 on: November 06, 2019, 07:17:17 pm »
I just did some tests with another motor, this one has 6 pole pairs (the original one that I need to use has 8 pole pairs), but I have the same results... I feel there is a problem with the library. Hope we can find out the problem soon
  • Country: pt
« Reply #356 on: November 06, 2019, 07:36:39 pm »
Therefore, you cannot guarantee under what conditions the AB signal reaches the MCU ...
When possible check the AB signals with the oscilloscope. Just to make sure the feedback is working correctly.
Offline r0d3z1
« Reply #357 on: November 11, 2019, 08:22:57 am »
what library version are you using ? I am currently using the 5.4 with only encoder as feedback and it works. For sure your motor phase order have to be correct.
Offline psyke
  • Country: ar
« Reply #358 on: November 12, 2019, 02:15:16 pm »
Well... yesterday I recorded some videos showing the oscilloscope and the motor control workbench, and I came here to post them, but when I read r0d3z1 comment, I thought: I'm going to try a last thing, so I interchanged the connection of two phases.... and it worked  |O  :palm:  :scared:
Thank you to all who helped me
  • Country: pt
« Reply #359 on: November 12, 2019, 02:28:12 pm »
Story Summary:
Glad to know it already works ;)
The following users thanked this post: psyke
Offline r0d3z1
« Reply #360 on: November 12, 2019, 05:10:33 pm »
I am pleased that it worked.
I would like to ask you if you are using the library with the ihm08m1 board ? i am currently using it and the current reading are very noisy due to the switching noise induced by the buck converter. Anyone notice this ?
Offline psyke
  • Country: ar
« Reply #361 on: November 13, 2019, 12:04:08 am »
Thank you  :)
I started with a P-NUCLEO-IHM001 (NUCLEO board with STM32F302R8 and an IHM07M1). After testing the library with that board, I designed my own PCB based in IHM08M1 schematics. I literally copied the current sensing part, and it's working nice on my board.
How much current does your motor consume?
If you get noisy current reading, I would start increasing T-noise and/or Trise in "Current Sensing" block in ST Motor Control Workbench, and recompile.
« Last Edit: November 13, 2019, 03:40:49 am by psyke »
Offline psyke
  • Country: ar
« Reply #362 on: November 19, 2019, 05:01:47 pm »
Hi, I'm back again, but this time I don't have any problem, just a question.
Does anyone know if you can do position control with this library? Because I can't find a way to do that, only speed control
Thank you
Offline r0d3z1
« Reply #363 on: November 20, 2019, 11:31:48 am »
As far as I know position control is not supported by the library, but you can add it by yourself.
Offline r0d3z1
« Reply #364 on: January 13, 2020, 10:51:55 am »
Anyone using this library with encoder is having oscillation problem on speed loop ?
I have seen that there is no LPF of speed feedback and the sampling is very slow (1ms).
Offline psyke
  • Country: ar
« Reply #365 on: January 13, 2020, 03:27:25 pm »
Hi r0d3z1
I have a little oscilation in speed feedback but it isn't significant.
Does it get unstable due to the oscilation in speed feedback?
If you are using encoder you can increase the input filter in the workbench.
Maybe you could also post a short video showing the behavior.
Also check if changing motor parameters you get better results
« Last Edit: January 13, 2020, 04:34:33 pm by psyke »
Offline ozgurazazi
  • Country: tr
« Reply #366 on: June 25, 2025, 02:17:22 pm »
hello community. i have a f303re card and an ıhm08m1 card. i need to drive a bldc motor with foc control. but i am encountering some problems.
1) although i enter the nominal speed as 1000rpm, it goes up to 2300rpm in the motorpilot interface and i cannot control the speed.
2) the power supply i have can provide max 5A current. the motor draws max 24A current. i am getting an overvoltage error.
what is the reason for these problems?
can you please help?its my final exam ı must finish in 2 weeks.
Offline tatus1969
    • keenlab
« Reply #367 on: June 26, 2025, 11:51:20 am »
it's possible that the motor commutation is off angle, or the motor spinning direction is wrong. in that case the controller may fully open up, trying to have it spin in the wanted direction where it doesnt.
the overvoltage error isnt related to current draw, but a sign of regen operation. this happens when decelerating the motor's inertia. the regenerated energy is pumped into the dc bus capacitance, with no limit to that basically -> voltage climbs to infinity. either increase capacitance, or add brake resistor. quick fix is to put a battery in parallel (-> close to infinite capacitance).
The following users thanked this post: ozgurazazi
