Author Topic: prolific usb to serial comm port driver windows 10  (Read 8821 times)
Offline ParthTopic starter
  • Country: in
« on: May 01, 2018, 04:52:53 pm »
I am trying to connect my microcontroller development board  with laptop using usb to serial cable. I have Windows 10. I have been searching a lot for  suitable driver but I haven't found any suitable driver
How to find prolific usb to serial comm port driver windows 10
Offline iMo
  • Country: sm
Re: prolific usb to serial comm port driver windows 10
« Reply #1 on: May 01, 2018, 11:45:18 pm »
  • Country: in
« Reply #2 on: May 02, 2018, 02:56:20 am »
I have already tried but nothing work.
Offline IanB
« Reply #3 on: May 02, 2018, 03:21:24 am »
In the Prolific user guide there is a warning. Could that be a problem for you?
Counterfeit Warning!!!
Please be warned that counterfeit/fake PL-2303HX Rev A (or PL-2303HXA) USB-to-Serial Controller
ICs using Prolific's trademark logo, brandname, and drivers, are being sold in the China market.
Counterfeit IC products show exactly the same outside chip markings but generally are of poor quality
and causes Windows driver compatibility issues (Yellow Mark Error Code 10 in Device Manager under
WinXP, Vista, and 7). This warning is issued to all customers and consumers to avoid confusion and
false purchase. Please purchase only from stores or vendors providing technical and RMA support.
Online Monkeh
« Reply #4 on: May 02, 2018, 03:58:28 am »
There's counterfeits. There's also the fact that they actively don't support older chips.
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #5 on: May 02, 2018, 05:32:06 am »
You may have to disable driver signing in Windows 10.
[2c]
Wrong code should not compile!
Offline iMo
  • Country: sm
« Reply #6 on: May 02, 2018, 10:29:11 pm »
I use a fake prolific with one of my rig and Win7. I got it with my radio many years back.
The trick here is to use older drivers (1.6.1, 1.7.0, etc), and, disconnect from network when a) installing the driver, b) when inserting prolific into the usb port. The installation sometimes requires a remove/install looping.
  • Country: in
« Reply #7 on: May 03, 2018, 02:24:53 pm »
Many thanks. What could be possible solution to install driver other then buying new one ? New one is last option or still there is some possibilities?
Offline metrologist
« Reply #8 on: May 03, 2018, 03:30:04 pm »
The ftc has been totally sucking in protecting consumers. There is no outlet for these things, legitimate or not, that are not sourced from China and the  majority of consumers are using eBay, which for some strange reason seems to be immune from anything except profit.
Offline BravoV
  • +++ ATH1
« Reply #9 on: May 03, 2018, 03:32:24 pm »
No, take the last option.
Offline BillB
« Reply #10 on: May 05, 2018, 07:44:56 pm »
There is an implementation of an older driver repackage that I have used several times.  In fact, I just used it to successfully interface to a Maynuo RS-232/USB cable for my Windows 10 x64 PC:
http://www.ifamilysoftware.com/news37.html
Yeah, the website is a little hokey, but it is legit.  (Says a stranger on the internet)
The following users thanked this post: iMo
Offline Porama6400
  • Country: th
« Reply #11 on: May 06, 2018, 03:08:40 pm »
I suggest buying a new one, Even if you manage to find a driver that work you will have to reinstall it every time you boot your computer
Trust me, it's not worth it.
« Last Edit: May 06, 2018, 03:13:31 pm by Porama6400 »
Offline iMo
  • Country: sm
« Reply #12 on: May 06, 2018, 04:16:19 pm »
I've tried with my old HX, almost impossible to install in my Win7 64bit.
It works first time! :)
The only issue I see is when I plug the dongle into a different usb port it shows an unsuccessful installation. When I plug it back to the port in which I installed it first time, it works.
PS: the driver shows: Prolific 27-Oct-08 3.3.2.105
The CheckChipVersion v 1006 says "This is a PL-2303 XA / HXA chip"
PPS: You have to install it on every usb port you want to use with the 2303 individually..
« Last Edit: May 06, 2018, 05:15:00 pm by imo »
Online Monkeh
« Reply #13 on: May 06, 2018, 07:12:10 pm »
Nuts to that.
Throw the Prolific stuff in the bin where it belongs.
Offline metrologist
« Reply #14 on: May 07, 2018, 02:22:01 pm »
that's the way all this kind of stuff works for me. ftdi, prolific, and ms all crap.
