Author Topic: Proper Design approach: Buffering of I/O on an FPGA  (Read 7734 times)
Offline Pack34Topic starter
« on: February 03, 2016, 09:41:31 pm »
One thing I noticed when working with Vivado is that some generated code always seems to add a buffer on the input and the output. Is this a more proper design approach than just wiring the signal out?
The main reason I ask this is that I'm currently debugging a design and when I probe one of the outputs it seems to have an effect on the overall timing of a portion of the logic. Almost as if the added capacitance of the probe is slowing something down and causing a race condition to occur.
Should all I/O have a simple buffer to protect the internal logic of the FPGA?
« Last Edit: February 03, 2016, 09:53:30 pm by Pack34 »
Offline andre_teprom
  • Country: br
    • Aluis-Rcastro
Re: Proper Design approach: Buffering of I/O on an FPGA
« Reply #1 on: February 03, 2016, 10:47:48 pm »
According to pag. 21 of this datasheet, you can disable that option:
You can also set the -mode to out-of-context in the Synthesis Settings > More Options view.
This setting ensures that synthesis does not insert I/O Buffers into that module.
"Part of the world that you live in, You are the part that you're giving" ( Renaissance )
« Reply #2 on: February 03, 2016, 10:56:00 pm »
I was more curious if was "better design" to do so.
Offline xygor
« Reply #3 on: February 03, 2016, 11:11:35 pm »
What fpga are you talking about?
You can't *not* have an io buffer.  The fabric does not have direct access to pins!
« Reply #4 on: February 03, 2016, 11:26:26 pm »
I'm working with a Spartan6.
  • Country: br
    • Aluis-Rcastro
« Reply #5 on: February 03, 2016, 11:28:17 pm »
There is perhaps a misunderstanding of the I/O of a module or a chip.
Offline hamster_nz
« Reply #6 on: February 03, 2016, 11:39:36 pm »
The I/O buffers are inescapable.
To get a signal off of the FPGA fabric and out to a pin it has to go through an output buffer. Likewise to get a signal from the outside world onto the fabric it has to go through an input buffer. If you disable the automatic insertion of I/O buffers then I guess you will get Place and Route failures if your signals lack them.
Situations where you must explicitly create the required I/O buffers include using differential I/O standards, or if you want to control the signals I/O attributes from within the HDL source rather than with external constraints.
For single ended inputs or outputs I don't explicity add the buffers. For tristate pins I've moved away from using tristate signals in my designs and use explicit tristate buffers. Using tristate signals and leaning on the tools to implement it just doesn't seem to work. I usually end up with placing the tristate buffer in the design's top level design and the having pin_input, pin_output and pin_tristate signals being passed up/down into the deeper level of the design.
For me, I find it helpful for the internal design to match the actual physical implementation within the FPGA, but that is just me - I'm sure others will argue I am foolish to not use the tiny level of abstraction that tristate signals gives.
As a start for best practice, have a look at http://www.xilinx.com/support/documentation/sw_manuals/ug949-vivado-design-methodology.pdf
Infer I/O Components Near the Top Level
Where possible, infer I/O components near the top level for design readability. Components that can be inferred are simple single-ended I/O (IBUF, OBUF, OBUFT and IOBUF) and single data rate registers in the I/O. I/O components that need to be instantiated, such as differential I/O (IBUFDS, OBUFDS) and double data-rate registers (IDDR, ODDR, ISERDES, OSERDES), should also be instantiated near the top level.
Edit: This also holds true for Spartan 6.
« Last Edit: February 03, 2016, 11:41:52 pm by hamster_nz »
Offline nctnico
« Reply #7 on: February 04, 2016, 12:21:12 am »
Also don't forget to add timing constraints between the outside signals coming in to the flip-flops and from the flip-flops to the signals going out. If you don't have these timing constraints you can have severe routing delays and you can get all kinds of weird timing problems with the external devices connected to the FPGA.
« Reply #8 on: February 04, 2016, 02:32:11 pm »
.... I will look into this. Thanks!
