I'm recently working on a simple boost converter controller based on any MCU I can find. As a long time PSoC developer, my first thought was PSoC 5LP running at 80MHz, which gives 12.5ns PWM resolution.
I know I can use C2000 or dsPIC33GS series, but I would like to hack the converter as quick as possible, and it just happens that I have a PSoC5888 board lying around (the $10 gum stick kit), plus the ability to use 5V logic makes interfacing easier.
My question is, is there a way to gain even better PWM resolution by using UDB as delay line? I only need to interpolate PWM resolution by 4, so ~3ns predictable delay is perfect. Thanks in advance.----------Solved----------Solution: using logic gates to create delay line and disable logic optimization in build settings.
Tap resolution is ~2.3ns. Not dynamically calibrated, but for such a coarse tap resolution (compared with down to 55ps for some C2000), I highly doubt if dynamic calibration is necessary.
Code attached for those who wants to build SMPS with PSoC5, and I believe if you have tools to measure ns level delay, you can also port the code to PSoC3 or PSoC4.
Since tap resolution is ~2.3ns, I set PWM clock ti 72MHz, so that 1/72MHz=13.9ns is close to an integer multiple of 2.3ns, in this case, the multiplier is 6. Each PWM LSB is divided into 6 sub slots with delay line to allow 6x resolution.
Test result:
n=6: t_on=14.9ns
n=7: t_on=17.5ns, delta=2.6ns
n=8: t_on=19.8ns, delta=2.3ns
n=9: t_on=22.2ns, delta=2.4ns
n=10: t_on=24.8ns, delta=2.6ns
n=11: t_on=27.1ns, delta=2.3ns
n=12: t_on=29.1ns, delta=2.0ns
Here when n=12 (or any n where n%6=0), delta t is a bit lower due to tap position revolves every 6 of n, and hence there will be some random error caused mismatching of oscillator period and delay line period, and for me, 0.6ns timing error is good enough.
----------Update----------With some fine tuning, I settled at fosc=68MHz, and delta t per step is as follow (measured with high res mode of my scope):
2.36ns
2.48ns
2.29ns
2.53ns
2.37ns
2.53ns
It seems fairly decent to me, at least for SMPS applications.
This average tap size of 1/(68MHz*6)=2.45ns allows 10bit PWM resolution even at 400kHz, and 9bit resolution at 800kHz. What's more, it is free if you already have PSoC in your system.
Considering the PSoC5 LP gum stick board is only $10 at 1pcs (the 2 chips on board along are $20+ at 5kpcs), I just ordered a few more of them for my other projects.
I can finally say goodbye to F28377S and dsPIC33EP32GS202. They are just too hard to develop (limited resource of demo cases, and less easy to use library support) compared with PSoC family, and I'm not a professional embedded engineer.
