Author Topic: DAC outputs on Arduino Due not working...  (Read 4326 times)
Offline BoscoeTopic starter
« on: June 27, 2017, 10:42:17 am »
Hi all,
Something that I though would be easy to do, output values on the DAC, is proving very frustrating. I have the same issue on two Arduino Due boards. Whatever code I try from examples the outputs are always high impedance.
I've tried setting the DAC pins as outputs or nothing, changing the resolution etc. One issue I found online was to do with writing to the DACs too quickly however I only write it once. Both DAC outputs suffer from the issue.
Any advice would be great!
Thanks.
Some code:
void setup() {
  pinMode(DAC0, OUTPUT);
  analogWriteResolution(12);
  analogWrite(DAC0, 2048);
void loop() {
  if(digitalRead(SW_START) == 1)
    enableDischarge(4);
  else
    disableDischarge(4);
  delay(1000);
Offline sokoloff
Re: DAC outputs on Arduino Due not working...
« Reply #1 on: June 27, 2017, 11:08:45 am »
Have you tried pulling the analogWrite statement into the loop()?
Have you tried a simpler, 8-bit DAC code?
void setup() {
  // initialize the digital pin as an output.
  pinMode(5, OUTPUT);
void loop() {
  analogWrite(5,127);  //Set the PWM at 50 % on digital pin 5
Or other code examples:
https://www.arduino.cc/en/Reference/AnalogWriteResolution
« Reply #2 on: June 27, 2017, 11:36:27 am »
void setup() {
  pinMode(5, OUTPUT);
void loop() {
I copied and pasted your code however changed the pin to 35 - but get nothing on the output :(
Offline Rerouter
« Reply #3 on: June 27, 2017, 12:56:09 pm »
try removing the pin definition, arm peripherals have far more features than you would expect on them, so it may be that its both outputtting on the dac, and outputting a 0 to the pin, thus grounding that output
for more references, see here https://forum.arduino.cc/index.php?topic=154965.0
