Author Topic: Pulse Oximeter using Arduino Uno, Raspberry Pi and Xprotolab  (Read 39138 times)
Offline elektronchika
  • Country: bg
    • Elektronchika's blog
Re: Pulse Oximeter using Arduino Uno, Raspberry Pi and Xprotolab
« Reply #25 on: February 04, 2016, 07:39:46 am »
Interesting threat.
I also try to make a HR and SPO2 monitoring. I have all the hardware and I can plot the graphs of the IR and RED leds. Everything is good so far but HOW DO I DO the calculations inside a low-power microcontroller. In TI's SLAA274B there is a band-pass filter, zero-crossings (I thing the block diagram is wrong - zero crossing should be done after the BP filtering) and RMS calculations. All of these are too hard to make in a MSP430. That's why in all these App notes they send the data to a PC and the PC makes the calculations.
So, I'm stuck at this points. Any suggestions from you guys?
Cheers!
Offline coppice
« Reply #26 on: February 04, 2016, 08:59:11 am »
Interesting threat.
Cheers!
All the calculations in that app. note are performed on the MSP430. Only the final results are sent to the PC for display.
Offline HAL-42b
« Reply #27 on: February 04, 2016, 09:58:48 am »
Turns out an Open Source Pulse Oxymeter is A LOT more important than any of us realized.
From around 20:00 but obviously watch the whole thing to get the context.
Offline jpereira.ca
« Reply #28 on: October 20, 2020, 05:30:18 am »
In the end, was anyone able to connect a Nellcor Pulse Oximeter to an Arduino, and get the calibration data from the OTP EPROM on DB-9 pins 4 and 8?
Also, what OP-AMP did you end up using to convert the current range to an Arduino-readable voltage range?
Many thanks in advance!
