Yes, it works now, but there is a problem. When the positive phase of the signal reaches to peak, it goes to zero. The other thing is that sine wave is not continuous. After at the end of the one full sine wave, there is a long delay. What do you think about these two problems? I also attached the output signal with a photo.
Updated code is
uint16_t testdata_out[256]={128,131,134,137,141,144,147,150,
153,156,159,162,165,168,171,174,
177,180,183,186,188,191,194,196,
199,202,204,207,209,212,214,216,
219,221,223,225,227,229,231,233,
234,236,238,239,241,242,244,245,
246,247,249,250,250,251,252,253,
254,254,255,255,255,256,256,256,
256,256,256,256,255,255,255,254,
254,253,252,251,250,250,249,247,
246,245,244,242,241,239,238,236,
234,233,231,229,227,225,223,221,
219,216,214,212,209,207,204,202,
199,196,194,191,188,186,183,180,
177,174,171,168,165,162,159,156,
153,150,147,144,141,137,134,131,
128,125,122,119,115,112,109,106,
103,100,97,94,91,88,85,82,
79,76,73,70,68,65,62,60,
57,54,52,49,47,44,42,40,
37,35,33,31,29,27,25,23,
22,20,18,17,15,14,12,11,
10,9,7,6,6,5,4,3,
2,2,1,1,1,0,0,0,
0,0,0,0,1,1,1,2,
2,3,4,5,6,6,7,9,
10,11,12,14,15,17,18,20,
22,23,25,27,29,31,33,35,
37,40,42,44,47,49,52,54,
57,60,62,65,68,70,73,76,
79,82,85,88,91,94,97,100,
103,106,109,112,115,119,122,125};
/* USER CODE BEGIN 3 */
for (i=0; i<256; i++)
HAL_GPIO_WritePin(DAC_SYNC_GPIO_Port, DAC_SYNC_Pin, GPIO_PIN_RESET);
//DACA_Buf = DAC_A_Write<<12 | testdata_out<<4;
DACA_Buf = DAC_A_Write<<12 | testdata_out[i]<<4;
HAL_SPI_Transmit(&hspi2,(uint8_t*)&DACA_Buf,16,100);
HAL_Delay(1);
HAL_GPIO_WritePin(DAC_SYNC_GPIO_Port, DAC_SYNC_Pin, GPIO_PIN_SET);
DACB_Buf = DAC_B_Write<<12 | testdata_out[i]<<4;
//DACB_Buf = DAC_B_Write<<12 | testdata_out<<4;
HAL_SPI_Transmit(&hspi2,(uint8_t*)&DACB_Buf,16,100);
HAL_Delay(1);
