Author Topic: PWM with atmega324pa  (Read 2395 times)
Offline MarkoAnte
« on: December 26, 2013, 12:36:05 pm »
I'm trying to make a pwm signal and I started by using this code:
 * Voscilnicaosciloskop.c
 * Created: 24.12.2013 15:10:32
 *  Author: Alucard
#define F_CPU   18432000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
double dutycycle = 0;
int main(void)
   DDRB = 0xff;
   TCCR0A = (1 << COM0A1) | (1 << WGM00) | (1 << WGM01);
   TIMSK0 = (1 << TOIE0);
   OCR0A = (dutycycle/100.0)*255;
   sei();
   TCCR0B = (1 << CS00);
   while(1)
      _delay_ms(100);
      dutycycle += 10;
      if(dutycycle > 100)
         dutycycle = 0;
ISR(TIMER0_OVF_vect)
The problem I have is wiht the delay. I set the fuse bits so that the cpu runs off a external 18.432 Mhz clock and I get a 71.9 kzh pwm output - witch is ok as 18mhz/255(8 bit timer)- is the 72 kzh signal. The problem is that it is really slow on the delay, it hold the same duty cycle for a long time, the problem is fixed when I enter the f_cpu as the 72 khz I'm getting form the pwm output.
Why is this and how do I make it work properly?
Offline dannyf
Re: PWM with atmega324pa
« Reply #1 on: December 26, 2013, 02:59:22 pm »
Why is this
Easy:
1) compare the code vs. the datasheet to see what it is trying to do;
2) then figure out if it is doing what it is trying to do.
3) if not, try to figure out how to do what you are trying to do.
Offline filip_cro
  • Country: hr
« Reply #2 on: December 26, 2013, 08:30:56 pm »
What kind of signal are you trying to make?
Now you get change every 100 ms ( by using _delay_ms(100); ) in while loop. Understand?
Why not putting something like OCR0A += 25; in TIMER0_OVF interrupt. And use OCR0A interrupt so you wont lose count if OCR0A = 255.
Offline Lajon
« Reply #3 on: December 26, 2013, 09:18:35 pm »
No far from that - this is the problem OP is having.
The main program (which is mainly the _delay_ms call) is starving because of the heavy computation done in the ISR. There is really no need to use a double in this program - also no need to compute the value for OCR0A inside the ISR. You can add a counter inside the ISR and base the timing in main on that (or use another timer) but the delay_ms will approach 100ms if the ISR is made (a lot) faster.
Offline filip_cro
  • Country: hr
« Reply #4 on: December 26, 2013, 10:36:34 pm »
Well he wouldn't see difference between 7190 and 7191 times of x% duty cycle. And he said that problem was sold by using smaller delays (by using smaller frequency F_CPU) so he probably want change every time timer is started.
