Author Topic: Quartus / USB Blaster / Windows 10 blue screen of death  (Read 25133 times)
Offline MacbethTopic starter
« on: November 30, 2015, 11:01:33 am »
I previously used Quartus II Web Edition 14 on my desktop Win 7 with my clone USB Blaster without issue. Since upgrading to Win 10 I get blue screens when trying to use the Blaster. I've got the latest Quartus Prime Lite 15.1 and still have the same problem with the drivers. I've also tried with a fresh install of Win 10 on my laptop.
Thankfully the linux kernel driver works just fine so I dual boot into Ubuntu but it can be a drag when most of my other work I get up to runs under windows.
Anyone else using Win 10? I am beginning to suspect Altera are doing an "FTDI-gate" with their win drivers to root out all the clone hardware  :-\
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
Re: Quartus / USB Blaster / Windows 10 blue screen of death
« Reply #1 on: November 30, 2015, 08:48:05 pm »
Not sure about the blaster but the supported windows version for 15.1 is 8.1 - the simulator is only good for windows 8.0.
So you're on unsupported territory with Windows 10...
Wrong code should not compile!
« Reply #2 on: November 30, 2015, 09:46:49 pm »
I'll stick with the Ubuntu dual boot I think. I might try a VirtualBox in Win 10, but it's slow enough as it is!
Offline Kjelt
« Reply #3 on: November 30, 2015, 09:49:32 pm »
Can you in win10 select the compatibility mode for that program and choose win7 or 8 ?
http://www.laptopmag.com/articles/set-compatibility-mode-windows-10
« Reply #4 on: November 30, 2015, 09:57:21 pm »
Not really, it's not the Quartus application but the USB Blaster drivers that are crashing windows. A hardware fault.
Offline Rasz
    • My random blog.
« Reply #5 on: December 01, 2015, 07:30:25 am »
thats what virtual machines are for
some people even keep separate VMs per client/project
Offline 1uk3
  • Country: at
« Reply #6 on: December 01, 2015, 09:54:13 am »
The original USB Blaster works fine here  :o (Win10 Pro N 64bit)
I ordered a clone from china, will post here as soon as it arrives(~2 weeks)
Offline kscarbery
« Reply #7 on: December 18, 2015, 08:01:09 pm »
I am experiencing what could be the same BSoD with a bugcheck of PFN_LIST_CORRUPT: 0x4E (0x9A, 0x425536, 0x6, 0x2) https://msdn.microsoft.com/en-us/library/windows/hardware/ff559014%28v=vs.85%29.aspx. I'm running Windows 7 x64 with Quartus Prime 15.1.0 Build 185. I'm seeing the BSoD immediately after trying to load the driver for the (generic) USB Blaster.
« Reply #8 on: December 18, 2015, 08:12:21 pm »
I managed to overcome my USB Blaster BSOD problems. I got an FPGA board from AliExpress that had a spare USB Blaster with it. That one worked.  :-+
See my post here https://www.eevblog.com/forum/microcontrollers/beginner-fpga-dev-board/67/
Offline kscarbery
« Reply #9 on: December 18, 2015, 10:10:38 pm »
Wow, changing to a different USB Blaster clone also solved my problem. The Terasic Blaster is working fine for me.
Online free_electron
    • SiliconValleyGarage
« Reply #10 on: December 18, 2015, 10:21:15 pm »
if i remember right the blaster uses an ftdi chip ....
fake china blasters may have fake ftdi's in em ... er emulated using a cypress chip ...
not altera's fault.
Offline marshallh
    • retroactive
« Reply #11 on: December 19, 2015, 01:01:31 am »
I'm currently using one that uses a PIC18F14K50 and an octal buffer. It's actually slightly faster than the real one.
Verilog tips
BGA soldering intro
« Reply #12 on: December 19, 2015, 11:20:43 am »
Yep, that looks the same as my (new) one  :-+
Offline miguelvp
« Reply #13 on: December 20, 2015, 04:15:05 am »
Speaking of Quartus, has anyone migrated to the new Quartus Prime Lite?
https://www.altera.com/products/design-software/overview.html
Are we going to loose features compared to Quartus II Web Edition?
https://www.altera.com/products/design-software/fpga-design/quartus-prime/download.html
Offline tpw_rules
« Reply #14 on: December 20, 2015, 07:49:01 pm »
How do you all run the driver with windows 10 anyway? I'm using a Terasic board and I can't find a signed driver for it. Every time I reboot, I have to go back into debug options and disable signing to be able to do anything. Super obnoxious. Never had a blue screen though.
Offline miguelvp
« Reply #15 on: December 20, 2015, 08:01:54 pm »
To tell you the truth, I don't think I fired up Quartus since my Windows 10 upgrade.
Offline marshallh
    • retroactive
« Reply #16 on: December 21, 2015, 02:46:09 am »
Legit USB Blaster Rev C:
Verilog tips
BGA soldering intro
« Reply #17 on: December 21, 2015, 02:13:08 pm »
I'm using the Altera driver that comes with Quartus. In my case that's C:\altera_lite\15.1\quartus\drivers
Offline DuMOHsmol
  • Country: ru
« Reply #18 on: February 13, 2017, 08:41:46 pm »
For those suffering BSODs (or hanging Quartus) with cloned USB Blasters, try this driver: http://www.alteraforum.com/forum/showthread.php?t=19233. Or (mirror) https://yadi.sk/d/lLD5vgk03E2Hb3. Or get it from this post :) You may need to disable driver signature enforcement to install it. Worked for me!
« Last Edit: February 13, 2017, 08:46:16 pm by DuMOHsmol »
The following users thanked this post: denimdragon
Offline p_wolf
« Reply #19 on: September 19, 2017, 09:39:20 am »
Thank you very much! The driver works fine for me with  Woindows 10 and Altera prime 16.1!
