I turned the scope off and on and for a few shots it started decoding the H and L. I twiddled with the trigger levels for SDA and SCLK and it seemed sensitive to that but the best results were near the middle of the waveforms (about 2.5V). After a few successes it went into lala land. I'm playing with the When, AddrBits, Address, and Directions settings but I'm not sure if I have those right - might be the settings where I'm off.
I think the answer might be sitting in the LogicPort images above. I'm just starting to learn I2C and I'm not sure what the S, A, and P stand for; and I'd guess 2h might be code for the 5 address... but as you can see, I'm just guessin'. Need some help from an experienced I2Cer, Plz, Thx.
Update: Always good to Read The Fine Manual (Intronix has pretty good help/documentation). S is start (duh), A is Acknowledge (sort of duh), HS is High Speed, and P is Stop (go figure). Now I just need to figure out how to use this info to get the Rigol to do it's thing properly.
