Author Topic: Raspberry Pi Pico  (Read 75812 times)
Offline DavidAlfa
Re: Raspberry Pi Pico
« Reply #300 on: March 15, 2021, 06:24:58 pm »
I've looking at it since it came out... The dual core really caught my attention.
It's amazing how fast MCUs are getting, multicore, even GHz clocks.
How good are the documentation and libraries vs stm32?
Offline exe
  • self-educated hobbyist
« Reply #301 on: March 15, 2021, 07:38:49 pm »
I've been wondering about the PIO for a while.
Can it be used for old-school parallel bus? Like 16 bit address 8 bit data? Or the 16 bit address + data multiplexed?
I'm no expert, but if you explain in more details may be I can help. PIO can pull/push in one go up to 32 pins.
Online tszabooTopic starter
« Reply #302 on: March 15, 2021, 08:31:27 pm »
Well, I know that you can write more than 1 GPIO pin at the time. Imagine the bus of a 6502. 16 bit address 8 bit data. R/W. PHI2 , which is a clock input for the bus. Maybe it should be an output for our theoretical system. DBE for external drivers.
All this is possible to do with a 100MHz microcontroller, for a 1MHz speed bus. I'm just wondering if it is possible to move it "one level down" and do it with the PIO, freeing up resources.
Offline thm_w
  • Non-expert
« Reply #303 on: March 15, 2021, 10:11:50 pm »
Saw a recent blog on measuring ADC performance of Pico: https://pico-adc.markomo.me/
Very well documented, DG4000 was used.
The following users thanked this post: hamster_nz, Dubbie, exe, aheid, DrG
Offline Nominal Animal
« Reply #304 on: March 16, 2021, 10:24:10 am »
Multiplexed yes, although I only looked at the PIO details to see if I could experiment with PDM with it (no, the PIO units have no adder).  Do check the datasheet for yourself, though.  The PIO instruction set is on page 341, I recommend reading from page 330 (Chapter 3. PIO) onwards.
The IN and OUT PIO instructions can set/get the state of any number of pins (up to 32), but the set is contiguous and always starts at the same pin (unless the 2040 modifies the PINCTRL register for that state machine).  So, for 16-bit address and 8-bit data, I think you could do it if you push 32-bit words to the FIFO, consisting of the data byte in the least and most significant bytes, sandwiching the address bits.  Writing the address would always write the data bits too (set all 24 pins).
The multiplexed form seems much easier.  Essentially, the PIO "program" will pop off an address, emit it to the PIO pins, and toggle the additional clock/read/write pin.  A read program will then read the PIO pins and push it to the 2040 proper; a write program will pop off the data, and emit it to the PIO pins.  Each instruction has an optional delay (generally, 0-31).  The limit of 32 instruction words per PIO unit (four state machines) might be an issue, but you'll need at least two of the state machines (read and write operations) anyway.  Autopull and wrap will reduce the number of state machine instructions you'll need.
I believe you can also do "block" DMA to the multiplexed bus, with the PIO program autoincrementing (or decrementing) the address.  For example, you supply the PIO program with the length of the data, the initial address, and the data (bytes or words), and it will write the interleaved address-data to the pins as needed, without the DMA'd data having the addresses interleaved.
Obviously, I haven't tried this myself, as I don't have a use for it, so there might be gotchas I haven't seen.
Offline ale500
« Reply #305 on: March 30, 2021, 05:28:04 am »
Did someone try with segger's embedded Studio ? According to their website the latest version (5.42) should have a package for the RP2040. But I do not see this package in the list of available packages. (I clicked on the non commercial license, I have an edu jlink).
Offline SiliconWizard
« Reply #306 on: March 30, 2021, 04:30:17 pm »
Thanks. It doesn't look that good, but I'm not very surprised.
Offline exe
« Reply #307 on: March 31, 2021, 08:50:00 am »
Btw, speaking of overclocking, according to [1], it seems most board can go up to 330MHz, and some go over 400MHz. Unfortunately, external flash stops working at much lower frequencies.
[1] https://www.raspberrypi.org/forums/viewtopic.php?t=301902
The following users thanked this post: thm_w, edavid, MK14
Offline Dubbie
« Reply #308 on: March 31, 2021, 09:48:57 am »
Wow that writeup on the ADC was really excellent.
Offline MK14
« Reply #309 on: March 31, 2021, 01:53:10 pm »
That's very interesting. That could mean that future releases of the PI Picos, could be at higher maximum clock speeds. It also means that anyone who understands the risks/problems with overclocking, could experiment with overclocking these modules.
It is possible they started out at the current 133 MHz limit, until they could do more tests and optimize the MCU, enough to safely go to higher maximum clock frequencies. Maybe it is the peripherals and/or external flash chip (as already mentioned, faster ones may not be available, are too expensive and/or may be unsuitable for other reasons), which are limiting the maximum reliable clock frequency.
N.B. Overclocking is NOT recommended for serious/professional/production applications/use.
« Last Edit: March 31, 2021, 01:57:59 pm by MK14 »
Offline guenthert
« Reply #310 on: June 01, 2021, 05:04:48 pm »
RP2040 chips (not the Raspberry Pico board) now available for $1.  Well, some 40000 of them at least.  In autumn larger quantities are expected.
https://www.raspberrypi.org/blog/raspberry-pi-rp2040-on-sale/
« Reply #311 on: June 01, 2021, 05:20:43 pm »
Now that's pretty cheap. I wonder how many of them they'll have to sell before they break even. (I'm also wondering about the licensing deal they got from ARM. Probably a pretty nice deal here.)
Offline guenthert
« Reply #312 on: June 01, 2021, 06:56:05 pm »
     I don't know the first thing about finances and have no insight into the details here, but my guess would be that the R. Pi Foundation as a non-profit organisation has written off the development costs and just needs to recoup OpEx.  And it's my (perhaps flawed) understanding, that chips, once developed, can be made fairly cheaply, if existing infrastructure can be utilized (no investment into better machinery needed).
Offline lucazader
« Reply #313 on: June 01, 2021, 08:56:53 pm »
Another thing to note here:
They are $1 in qty 1. (and right now discount for volume)
They do expect the per chip price to drop when they start selling full reels later this year.
source: https://www.cnx-software.com/2021/06/01/buy-raspberry-pi-rp2040-one-dollar/
alasdair allan made a comment on this article (he is the Technical Documentation Manager at rpi)
Offline brucehoult
« Reply #314 on: June 01, 2021, 11:07:22 pm »
Once you have the full-reticule mask set made -- which costs $800,000 for the 40nm node the RP2040 uses according to 2019 figures I found -- that stays in the library at the fab and one or more wafers can be run off at any time in the future for according to the same 2019 source $2274 per 40nm wafer
The die is 2 sq mm so a 300 mm wafer would be around 35000 chips. The cost per bare chip is therefore something like 6.5 cents.
Testing and packaging will be the main part of the cost, not the chip, especially if you're not trying to recover NRE costs.
« Last Edit: June 01, 2021, 11:10:11 pm by brucehoult »
The following users thanked this post: abraxalito, thm_w, lucazader
Offline lucazader
« Reply #315 on: June 01, 2021, 11:20:10 pm »
That makes it sound like for this first batch of chips that were produced, they only needed probably 2 wafers to get the 40k units that they are shipping, assuming a 60% ish yield.
That's pretty interesting.
How does the 2 sq-mm die size compare to similar chips from other manufacturers? (eg STM32G0/F0, ATMEL/PIC, NXP)
Edit: This article from 2014 seems to suggest around a 3.2 sq-mm die size for the KL03 line of chips
https://www.techdesignforums.com/blog/2014/02/27/freescale-kl03-mcu-design-tuning/
and the arm IP page give a bit more about the Die of the m0+ core without peripherals, around 0.006 sq-mm for the 40nm node
https://developer.arm.com/ip-products/processors/cortex-m/cortex-m0-plus
« Last Edit: June 01, 2021, 11:26:31 pm by lucazader »
Offline brucehoult
« Reply #316 on: June 02, 2021, 04:05:15 am »
The 0.006 mm^2 for a core is of course just the actual size of useful stuff.
I *think* the 2 mm^2 for the chip includes the space around the actual circuitry for the wires to be attached ("pads"), and also the gap for the saw to munch up to cut each chip out from the wafer.
The following users thanked this post: lucazader
Offline Rasz
    • My random blog.
« Reply #317 on: June 02, 2021, 06:57:57 am »
where did you get that from?
They are $1 in qty 1 and there are NO volume discounts, in fact it sounded like they prohibited dealers from selling more than 1 per person.
Offline lucazader
« Reply #318 on: June 02, 2021, 10:22:29 am »
as menioned in the original post:
Offline exe
« Reply #319 on: June 02, 2021, 10:31:13 am »
I've seen in one shop that they sell 1 piece max (which is weird), but here you can buy at least 10 if/when it's back in stock: https://www.okdo.com/us/p/raspberry-pi-rp2040-microcontroller-pack-of-10/?src=raspberrypi .
Unfortunately for me, it's not on sale yet in the Netherlands (or I didn't find it). I also bought a few rpi pico modules, so I'm probably still going to transplant ICs from them.
« Reply #320 on: June 02, 2021, 11:25:37 am »
There might be no volume discount, but here is a reel at farnell that can be ordered.
https://nl.farnell.com/raspberry-pi/rp2040tr13/mcu-32bit-133mhz-qfn-56/dp/3766080?CMP=GRHB-OCTOPART
RPI foundation has their right to set up their pricing policy. If it is "flat 1 USD" than its like that.
I dont mind the pricing, it seems very reasonable. It also doesn't put small players at a disadvantage.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #321 on: June 02, 2021, 11:59:34 am »
I ordered 20 pieces of RP2040 at PiAustralia at a unit price of 1.50 Australian dollars.
Offline phil from seattle
« Reply #322 on: June 02, 2021, 02:19:24 pm »
Hoping to get some clarity on volume soon.  I'm not sure how the flat rate thing will play out for distis.  In particular, for far east assemblers like JLCPCB. I think it would be awesome if I could have a RP2040 board assembled by them.
« Last Edit: June 02, 2021, 03:27:39 pm by phil from seattle »
Offline Rasz
    • My random blog.
« Reply #323 on: June 02, 2021, 04:12:28 pm »
so
-NO volume discount
-not selling more than 1 per person
>Note: this product is not in stock
>You can place a pre-order by clicking on the button, or indicate your interest by clicking on the link
its 1 usd same way RTX 2080 MSRP is $699
its the old Soviet trick - the pricing is always very reasonable when there is no merchandise in stock
« Last Edit: June 02, 2021, 04:22:10 pm by Rasz »
Offline thm_w
  • Non-expert
« Reply #324 on: June 02, 2021, 09:13:00 pm »
Because they are still producing them  :palm:
"Available to back order for despatch 04/08/2021"
https://uk.rs-online.com/web/p/microcontrollers/2211610/
