Author Topic: Question for older engineers, how did you get info?  (Read 10143 times)
Offline Gyro
Re: Question for older engineers, how did you get info?
« Reply #25 on: January 19, 2020, 12:39:10 pm »
The Nat Semi Linear Applications handbooks were always a good read, and mostly still very relevant today. You can find most of the App notes on the web, but it helps to know the AN number (I'm still looking for the one for the thermally servoed contact temperature sensor that was in one of the earlier editions I gave away!).
Best Regards, Chris
The following users thanked this post: fcb
Online ebastler
« Reply #26 on: January 19, 2020, 12:55:36 pm »
At this stage it feels like the OP is living up to his moniker / username :(
Yep, I had been wondering whether I should mention to him another "secret ingredient" engineers use to solve design problems: An extended attention span.  ;)
Online tggzzz
« Reply #27 on: January 19, 2020, 02:19:05 pm »
Tee hee. Too true.
Offline rstofer
« Reply #28 on: January 19, 2020, 05:28:29 pm »
Back in the early to mid '70s, microprocessors were a new thing.  There was no market for them, nobody had every used such a thing.  The manufacturers knew this and they went out of their way to publish databooks, app notes and other handouts to help designers bury uCs in their products.  These books were given out freely, even to hobbyists because hobbyists were just as advanced as working engineers, none of us knew where things were going.  We just had to get somewhere and do it fast.
It was a great time in my life.  The 8080 was available ($360), the Altair 8800 came out (somewhere less than $400 and that included the chip) and I was in grad school where we did our 1 unit Engineering Seminar writing papers about all of the new microcontrollers and their features.  We were flooded with manuals and handouts.
Nobody knew anything and we were all learning together.  Fun times!
And I worked for one of the largest semiconductor companies in the world, circa '76.  Datasheets and manuals were all over the place.  If you didn't know something, well, somebody did!  Hunt them down...
But you designed by yourself.  There may have been design teams but I wasn't part of that world.  I got the books, read through the app notes and started designing.  It was fun.  It also consumed a LOT of time.
Obviously, we didn't have the Internet to guide us along.  That may have been a blessing!  We actually had to READ the manuals, not rely on somebody else's interpretation.
Offline rstofer
« Reply #29 on: January 19, 2020, 06:06:38 pm »
The 8051 is a very well understood device and is still in production.  In fact, there are many advanced versions that have internal flash and RAM memory and are far easier to use.  But they still share the same architecture.
https://www.nxp.com/docs/en/brochure/75015973.pdf
The L6219 motor driver is not unlike any other bipolar stepper motor driver.  Figure 4 needs a lot of thought because it shows 1/3 current position holding, 1/2 current low speed and full speed.  Notice all the clocking shown in the middle panel.  This will take a little experimenting to figure out.  But it's all laid out and there is an application example.  Note that current is limited to 1A peak and 0.75A continuous.  That's not a lot!
Speed control is done by the rate at which pulses are sent to the driver - step commands.  This implies the use of at least one internal timer and some way to programmatically control the rate.  Timing (and interrupts) are everything.
https://www.st.com/resource/en/datasheet/l6219.pdf
There should be a ton of information on driving stepper motors with a uC.  Not necessarily an 8051 but the logic will be the same even if the code is totally different.
The TLC7528 DAC is a 2 channel parallel load DAC.  The application information in Figure 3 and Figure 4 is quite complete.  Again, a breadboard and some experimental code will be required.
I'm not sure what the DAC is doing relative to a stepper motor but I don't know anything about the end application either.
https://www.ti.com/lit/ds/symlink/tlc7528.pdf
It seems to me the OP needs to know a good deal more about the overall architecture of the existing boards.  A wee bit of reverse engineering will probably be required.  But the real work will be in writing the code.  Step one is to get all of the components talking together and step two is to get them to work in a real application.  This isn't going to happen overnight.  There's a lot to learn by reverse engineering even if the code isn't available.  How did the thing work?  What are the limitations of the application?  How do I apply one of the newer 8051 clones so I can get out of the EPROM business?  I want onboard flash and RAM!  How much did the original board have.
I might go so far as to walk away from the 8051 architecture and just use an ARM chip because the tools are more readily available and the processor is much more capable.  I really didn't like programming for an 8051 clone, even in Pascal (which I love).  That lower memory thing is a bother!
If the existing board uses external EPROMs, it will be easy to extract the code - not that it will be fun - but it should be possible to get to an assembly level.  Of course, given an optimizing C compiler, the assembly language will still be obscure.
Given that I am kind of lazy, I would probably design a brand new system using an ARM even if I did wind up using the same peripherals.  Of course, 3.3V vs 5.0V will jump up and bite me in the butt.
« Last Edit: January 19, 2020, 06:11:37 pm by rstofer »
Offline rstofer
« Reply #30 on: January 19, 2020, 06:17:00 pm »
Engineers solve problems by beating them to death with a club.  We build up sample circuits, breadboarding perhaps, then writing code until we understand all there is to know about interfacing to some device.  We look for the 'corners', places where the external device shouldn't go.  We try multiple approaches to coding a device, looking to gain intuition.  Basically, we beat it to death with a club.
Over many hours...
The following users thanked this post: worsthorse
Offline nfmax
« Reply #31 on: January 19, 2020, 06:28:25 pm »
It's Peter Lefferts, The monolithic temperature transducer - a new interfacing concept, AN-132, December 1974, in National Semiconductor Linear Applications Vol 2, 1976. The servo shield is on page AN132-5. I have a paper copy if you still can't find it.
The following users thanked this post: Gyro
Offline fcb
    • Electron Plus
« Reply #32 on: January 19, 2020, 06:31:12 pm »
You have to remember that 'back in the day' we had a fraction of the number of opamps/dacs/adcs/psu IC's/microcontrollers and VERY few RF IC's.  So most designs had a much higher component count than today - building a wireless transceiver would involve possibly hundreds of parts, especially if you had a synthesizer and two IF stages.
Electronics journal editorals or adverts would introduce you to new IC's, you'd ring or FAX the vendor or a distributor - they'd post out datasheets.  TI did well as they often blister packed a sample with the DS.  RS did datasheet 'packs' you could buy(!) and update these giant squishy covered blood-red ringbinders with. Most distributors published pinouts in the actual catalogues.
I had a 200sqft room that was wall to wall databooks including several yards of National books (BIBLE!), Texas blue/yellow books and Linear Tech pamphlets (application notes).  All binded off when PDF happened - feeling nostalgic.
Offline Gyro
« Reply #33 on: January 19, 2020, 07:21:16 pm »
Thanks nfmax, at least I know which one I'm searching for now. Sadly it took me a little while to notice that they were quietly dropping ANs between revisions, otherwise I would have jealously guarded the old ones too!
So much info didn't withstand the transition from the 'old days' to the current one. It's a case of scan it or loose it before it gets pulped (and then watch it drop down the search results until it's never to be found again!), eg, most searches only throw up the 1994 Linear Apps Manual.
Best Regards, Chris
Offline Noise Floor
« Reply #34 on: January 19, 2020, 07:42:53 pm »
We gathered whatever information we could get our hands on, and devoured it carefully to extract everything we could.
Then we sat down and thought, and understood.
Nowadays the key skill is the polar opposite: to quickly decide what to ignore.
So accurate.  Making this transition as access to information became pervasive took a while for many to adapt to. That said, there is a balance to be had between the two extremes, those folks usually are the most productive in my experience.
Offline profdc9
« Reply #35 on: January 19, 2020, 11:50:54 pm »
I worked for Motorola and so of course I got their databooks and used their parts.  A lot of really smart people worked there and I learned from them when I was younger.  I'm not even sure engineering organizations like Motorola exist anymore that keep talent like that long-term.  Motorola was supportive of electrical engineering education and provided databooks to the labs where I went to school, the University of Illinois at Urbana-Champaign.  Motorola was based out of Chicago so that was a no-brainer for them, as many of their employees were graduates of UIUC.
But despite today's information overload, yes it's way better to just to be able to get the information you need right away.  I don't feel nostalgic for the need to keep a huge set of manuals on hand.  I discarded mine a long time ago when I had to move between cities.  Breaking down barriers for engineering and creativity, as far as I can see, is always a good thing.
Offline schmitt trigger
  • Country: mx
« Reply #36 on: January 20, 2020, 02:28:58 am »
If you lived outside the USA, Canada or Western Europe, obtaining databooks in the 1970s was also very expensive.
Unless one worked for an University or large trans-national corporate, one had to order and pay for the databooks. On top of that, international shipping costs and customs fees.
The poster above who worked for Motorola may remember a set of three brown-cover databooks, dedicated to the discrete semiconductors in Motorola’s portfolio. The first two were for JEDEC-registered devices, the last one was for Motorola numbered devices.
For the set I paid, after all was said and done, close to $US 80. And those were 1970’s purchasing power dollars.
Likewise, for the Texas Instrument’s TTL Data Book for design engineers, the one with the ocre colored hardcover,  I paid $US 45.
Offline lazymanTopic starter
  • Country: cs
« Reply #37 on: January 23, 2020, 11:33:50 am »
Every company produced thick data books full of datasheets.  For more complex circuits like micros, there were design guides that combined datasheets with tutorial info on how to use them.  There were also lots of training courses that gave you a hands-on experience with the hardware.
I suspected that I'd find something at the Internet Archive.  I did.  :)
https://archive.org/details/bitsavers_intel8051M1_25397633
This one popped up on the first page.  There's probably lots more there.  I searched for < 8051 microprocessor > and specified "search text contents" .
Ed
Hi. Thanks a lot for this info, i have not know about the archive.org. Fine resource for texts before internet.
