Author Topic: Re: Arduino Encoder to Stepper Motor question, help?  (Read 123 times)
Offline bkukuk62
« on: September 17, 2019, 05:25:34 pm »
All,
I have been reviewing the following code from gman4925.   I would like to see if this could be modified to include a button that would break out of the interactive mode using the encoder for rotation to turning the stepper clockwise until another button is pushed using a potentiometer for speed control.
Has anyone done this that could help me.
thanks,
-Bkukuk62
//Arduino code for controlling stepper motor from encoder
//video at
//reconstructed code from 5+ years ago
//untested in current form
 #define encoder_a 2    //encoder a = arduino pin 2
 #define encoder_b 3    //encoder b = arduino pin 3
 #define motor_step 4    //motor step = arduino pin 4
 #define motor_direction 5    //motor direction = arduino pin 5
volatile long motor_position, encoder;
void setup ()
    //set up the various outputs
    pinMode(motor_step, OUTPUT);
    pinMode(motor_direction, OUTPUT);
    // then the encoder inputs
    pinMode(encoder_a, INPUT);
    pinMode(encoder_b, INPUT);
    digitalWrite(encoder_a, HIGH);
    digitalWrite(encoder_b, HIGH);
    // encoder pin on interrupt 0 (pin 2)
    attachInterrupt(0, encoderPinChangeA, CHANGE);
    // encoder pin on interrupt 1 (pin 3)
    attachInterrupt(1, encoderPinChangeB, CHANGE);
    encoder = 0;
void encoderPinChangeA()
    if (digitalRead(encoder_a) == digitalRead(encoder_b))
        encoder--;
    else
        encoder++;
void encoderPinChangeB()
    if (digitalRead(encoder_a) != digitalRead(encoder_b))
        encoder--;
    else
        encoder++;
void loop()
//do stuff dependent on encoder position here
//such as move a stepper motor to match encoder position
//if you want to make it 1:1 ensure the encoder res matches the motor res by dividing/multiplying
    if (encoder > 0)
        digitalWrite(motor_direction, HIGH);
        digitalWrite(motor_step, HIGH);
        digitalWrite(motor_step, LOW);
        _delay_us(200);
        motor_position++;
        encoder = 0;
    else if (encoder < 0)
        digitalWrite(motor_direction, LOW);
        _delay_us(200);
        motor_position--;
        encoder = 0;
Offline Nusa
« Reply #1 on: September 17, 2019, 06:20:40 pm »
Which part are you having trouble with?
Button/Switch or Potentiometer? Plenty of tutorials on those.
Speed? Change the delay value.
Logic?
  if (your_way)
    // your code
  else
    // existing code
