I recall that a more symmetrical hex pattern normal comes when it's encrypted so I guess it's not
If you program a new chip and put into the board where the old one was and it works you know it not encrypted
Also you could try to dissemble the dump and see if it makes sense
I also recall way back the the 8751 can run with external Eprom and some guy did that an output pin did drive the input pin telling to read internal or external.
In the external Eprom he had a uart code sending data to external terminal and when start sending he flipped the pin so the dump came from internal Eprom, pretty clever
