Hi all
I have this project in mind, rear signal light and brake to a ws2812b 12 led strip, 6 for a left signal turn yellow, 6 for a right turn yellow and 12 red led when brake. Because it is at the rear I need to take the 'signal' for my mini pro Arduino i/o pins from the light itself which will be 12 v. What I need to use to convert the ground and positive 12 v to a signal input for the pro mini?. Thanks in advance.
