Hey, sounds like fun! Have you got a helloWorld or blinky going?
I think OpenOCD can work in quite different ways on different systems. On the board I use most it works together with gdb to use JTAG over USB to download a small program into RAM on the MCU, which is then used to do self-programming of the flash. it's a lot of different stuff tied together with gaffer tape!
Hello.
Long discussing going on. I'm a bit out of it as I cannot discuss much about it.
About your question, yes, I made a blinky program working on it, but it was a ready-to-use source file that I just compiled with an also ready-to-use Makefile. I found an whole set of ready-to-use source files in github. I used them just to learn how OpenOCD works and also dfu-utils. I never worked with any of these tools.
But, just for the record, I have no prior experience. I'm just a mid age person that completed graduation in Electrical Engineering (Electronics and Telecommunications) in early 2018 and I developed an interest (and a passion, I guess) for electronics and programming, but NEVER worked on this area/field so I have only academic knowledge which is very limited so I struggle many times with real-world basic situations that were ignored in school, so we got no intuition whatsoever about real world scenarios. That is my complaint and regret for the unfortunate I was by not discovering this world years ago.
Anyways, I'm always trying to learn about new things but in the case of ARM, it was quite a big change because changed the architecture, changed the tools (avrdude mostly for AVR), changed registers, amount of things that needs to be configured, etc, etc.
And a reference manual of an ARM is like 1700 pages. AVR's (at least the one I was reading) was about 400.
Another thing I regret about myself is that I usually start something and then I just can't stick to it until the en. I think, in this field, my mind is very immature. I have at least 2 things, plus now the ARM chip, laying around doing nothing. On of them, I never tried it before, which was a small board I bought from china to try to listen/sniff/whatever Li-Ion battery controllers. The other one is a Mivrochip dev board called somethin like AVR IoT WG which comprises an AtMEga4808, some Google Cloud shit, a Wireless antenna, on-chip debugger , some security/cryptography/encryption feature and a couple of on-chip/built-in sensors. I started to explore this board but also dumped it after some time. I even had a small project to it but I lost interest, probably because to be able to use all these features all at once, a few thousands of lines of code were needed and it was a little bit of a daunting task to learn like 3000 lines of code just to read temp and light and send that info to some Google Cloud server and show it in some web page. I guess I lost the interest because of that huge amount of code.
Anyways, I always try to learn new things. I hope I can stick longer to ARM chips!
