Hi, which µC are you preffering and why?
Where to find a good reliable microcontroller, well documented, good debug features, fast to program, easy to learn good IDE, good programmer/debuger?
Or is there not the one and really depends on your needs what you prefer and which manufacturer you choose?
It depends on what your needs are!
How much I/O, and what types? How big will your program code be? How much data? What processing speed?
I keep a few 8 pin ATtiny85's on hand. There's a lot of places you can just poke one. They need zero external components, start up at 1 MHz from the factory but you can switch them to 16 MHz for a bit more ooomph. Six I/O pins (but be cautious about reusing the reset pin), up to 4 as ADCs, 8 KB FLASH, 512 bytes RAM, 512 bytes EEPROM. About a US$ each from Digikey etc in small quantity. Easy to download programs to using an Arduino as a programmer, using either the Arduino IDE or avrdude directly. Use Arduino libraries or bit bang the registers yourself -- it's all easy.
If you need more I/O then the good old ATmega328 has four times the I/O, program size, RAM for $2 each in DIP-28. And the ATmega2560 has another 4x the I/O and RAM and 8x the program size for $10. Sadly with so many pins they only come in BGA and 100-TQFP, so it's generally better to buy them on a $10 board -- same price as the bare chip, so why not? e.g.
https://www.amazon.com/dp/B07TGF9VMQThe only thing is all these run at exactly the same speed, run full speed only with 8 bit data, don't have an FPU etc. It's enough speed for many many purposes.
The next thing that's super easy to use, with lots of documentation, libraries, examples is the $20 Teensy 4.0. For that you get a 600 MHz 32 bit dual-issue ARM CPU with FPU, 1024 KB RAM, 2048 KB flash, 40 I/O pins (23 easier to use than the others)
https://www.pjrc.com/store/teensy40.htmlYou might consider a Teensy-LC for $12. It's got the same RAM, less flash, less I/O than the ATmega2560 at the same price but maybe around 10x the CPU processing power (but 20x less than the Teensy 4).
Again, Teensy board have a fantastic out-of-the-box getting started experience, great documentation and examples, work with the Arduino IDE and libraries or not -- your choice.
The RISC-V CPUs and boards coming out of China are looking very interesting.
The Longan Nano is $5 bought from China, $10 on Amazon. For that you get a 108 MHz 32 bit CPU, 128 KB flash, 32 KB RAM, a similar amount of I/O to an ATmega328 (swings and roundabouts) but 10x to 20x the processing power. And you get a small LCD display and plastic case thrown in for your $5.
There are also other boards using the same GD32VF103 chip -- which is close to being a clone of STM ARM chips with suspiciously similar product codes (and is in fact physically pin compatible) but with RISC-V CPU instead of ARM.
There are also the Kendryte K210 based RISC-V boards. These have pretty incredible specs, but a reputation for being not very well documented and hard to work with.
I think beginners should probably stay clear of these Chinese RISC-V boards for a while yet, even though they're very cheap and powerful.
