0. wire the stlink programmer properly1. press the board's reset button down and hold it pressed2. click Connect in the stlink utility3. release the reset button4. it should recognize the chip (provided it is supported by the stlink utility).
Then... Was it possible to detect the device using SWD with these PIN VOLTAGES connections? Because datasheet indicates two scenarios voltages less than 3V or around 2V..
