Hello,
Being relatively a beginner when it comes to electronics, there are just some things that confuse the hell out of me...
Is anyone able to explain to me what this sentence means:
"As inputs, Port 1 pins that are externally being pulled low will source current (IIL) because of the internal pull-ups."
If more context is required, the paragraph containing this sentence can be found on page 4 of the AT89S52 datasheet.
