Fluke 19X/B/C/II Firmware to Binary converter
FlukeFW2Bin.exe takes the firmware file (Tetra.ldf, or data.bin) from within Fluke's FlashTool
(F190_II_V11.44.exe, FlashTool_19xC_2xC_V804.exe, FlashTool_F190C_V615.exe, etc.)
and converts it into 2 binary files for analysis purposes.
The firmware on these Fluke Scopes uses the Nucleus PLUS - Version CL7111A RTOS what means
the uP is some form of ARM little-endian CL7111A probably similar to CIRRUS LOGIC CL-PS7111
The produced files binary must be loaded at 0x40000000 and 0x44000000
Entry point 0x40000080
Edit 01:
Tektronix THS3014/3024 apparently is a Fluke 190-104/204 II.
Best,
Pat
