In reading the CMSIS RTOS documentation I realised that the Mailbox is actually using the technique I am about to describe, it’s just that all the detail is hidden. The down side of it is that is doesn’t solve the problem of sending the same data to more than one thread as far as I can see.
I started with the code example for osMessageCreate() about half way down the message queue documentation here:-
https://www.keil.com/pack/doc/CMSIS/RTOS/html/group___c_m_s_i_s___r_t_o_s___message.html #include "cmsis_os.h"
osThreadId tid_thread1; // ID for thread 1
osThreadId tid_thread2; // for thread 2
typedef struct { // Message object structure
float voltage; // AD result of measured voltage
float current; // AD result of measured current
int counter; // A counter value
} T_MEAS;
osPoolDef(mpool, 16, T_MEAS); // Define memory pool
osPoolId mpool;
osMessageQDef(MsgBox, 16, T_MEAS); // Define message queue
osMessageQId MsgBox;
void send_thread (void const *argument); // forward reference
void recv_thread (void const *argument); // forward reference
// Thread definitions
osThreadDef(send_thread, osPriorityNormal, 1, 0);
osThreadDef(recv_thread, osPriorityNormal, 1, 2000);
// Thread 1: Send thread
void send_thread (void const *argument) {
T_MEAS *mptr;
mptr = osPoolAlloc(mpool); // Allocate memory for the message
mptr->voltage = 223.72; // Set the message content
mptr->current = 17.54;
mptr->counter = 120786;
osMessagePut(MsgBox, (uint32_t)mptr, osWaitForever); // Send Message
osDelay(100);
mptr->voltage = 227.23; // Prepare a 2nd message
mptr->current = 12.41;
mptr->counter = 170823;
osThreadYield(); // Cooperative multitasking
// We are done here, exit this thread
// Thread 2: Receive thread
void recv_thread (void const *argument) {
T_MEAS *rptr;
osEvent evt;
for (;;) {
evt = osMessageGet(MsgBox, osWaitForever); // wait for message
if (evt.status == osEventMessage) {
rptr = evt.value.p;
printf ("\nVoltage: %.2f V\n", rptr->voltage);
printf ("Current: %.2f A\n", rptr->current);
printf ("Number of cycles: %d\n", rptr->counter);
osPoolFree(mpool, rptr); // free memory allocated for message
void StartApplication (void) {
mpool = osPoolCreate(osPool(mpool)); // create memory pool
MsgBox = osMessageCreate(osMessageQ(MsgBox), NULL); // create msg queue
tid_thread1 = osThreadCreate(osThread(send_thread), NULL);
tid_thread2 = osThreadCreate(osThread(recv_thread), NULL);
It works exactly how the mailbox works except the message queue is visible. I took this example and modified it to share data across 3 threads without the need to copy. I also change the names of variables to match my buffer concept.
osThreadId tid_threadSource; // ID for main thread (data source)
osThreadId tid_thread1; // for thread 1
osThreadId tid_thread3; // for thread 3
typedef struct poolBuffer_s {
osMutexId RefCountLock;
uint32_t RefCount;
uint32_t DataCount;
uint8_t Data[BUFF_SIZE];
} poolBuffer_t;
osPoolDef(buffer_pool, 16, poolBuffer_t); // Define a pool of buffers
osPoolId buffer_pool;
osMessageQDef(MsgBox1, 16, poolBuffer_t); // Define message queue1
osMessageQId MsgBox1;
osMessageQDef(MsgBox2, 16, poolBuffer_t); // Define message queue2
osMessageQId MsgBox2;
osMessageQDef(MsgBox3, 16, poolBuffer_t); // Define message queue3
osMessageQId MsgBox3;
void recv_thread1 (void const *argument); // forward reference
osThreadDef(recv_thread1, osPriorityNormal, 1, 1000);
osThreadDef(recv_thread2, osPriorityNormal, 1, 1000);
osThreadDef(recv_thread3, osPriorityNormal, 1, 1000);
poolBuffer_t *buffptr;
for(;;)
if(checkDataReady == true)
buffptr = osPoolAlloc(buffer_pool); // Allocate memory for the message
buffer->RefCount = 3; // we are sending to 3 threads don’t need a mutex here as we haven’t set it yet
// Set the message content here maybe a video frame
osMessagePut(MsgBox1, (uint32_t)buffptr, osWaitForever); // Send Message to tread 1
osMessagePut(MsgBox2, (uint32_t)buffptr, osWaitForever); // Send same Message to tread 2
osMessagePut(MsgBox3, (uint32_t)buffptr, osWaitForever); // Send same Message to tread 3
osThreadYield();
} // Cooperative multitasking
void myBufferFree(poolBuffer_t *buffer)
osMutexWait(buffer->RefCountLock, osWaitForever);
buffer->RefCount--;
if(buffer->RefCount ==0)
osPoolFree(buffer_pool, buffer);
osMutexRelease(buffer->RefCountLock);
// Thread 1: Receive thread1
void recv_thread1 (void const *argument) {
poolBuffer_t *bufferReference;
osEvent evt;
for (;;) {
evt = osMessageGet(MsgBox1, osWaitForever); // wait for message
bufferReference = evt.value.p;
// process the buffer here eg give data to video card
myBufferFree(bufferReference); // free memory allocated for message
// Thread 2: Receive thread2
void recv_thread2 (void const *argument) {
osEvent evt;
for (;;) {
evt = osMessageGet(MsgBox2, osWaitForever); // wait for message
// process the buffer here eg save videodata to a file
// Thread 3: Receive thread2
void recv_thread3 (void const *argument) {
osEvent evt;
for (;;) {
evt = osMessageGet(MsgBox3, osWaitForever); // wait for message
// process the buffer here eg send video date to ethernet
buffer_pool = osPoolCreate(osPool(buffer_pool)); // create memory pool
MsgBox1 = osMessageCreate(osMessageQ(MsgBox1), NULL); // create msg queue
MsgBox2 = osMessageCreate(osMessageQ(MsgBox3), NULL); // create msg queue
MsgBox3 = osMessageCreate(osMessageQ(MsgBox4), NULL); // create msg queue
tid_threadSource = osThreadCreate(osThread(send_thread), NULL);
tid_thread1 = osThreadCreate(osThread(recv_thread1), NULL);
tid_thread2 = osThreadCreate(osThread(recv_thread2), NULL);
tid_thread3 = osThreadCreate(osThread(recv_thread3), NULL);
As you can see its almost exactly the same except that we send the same message to 3 queue instead of 1. Each thread decrements the reference count before returning the buffer to the pool. And that’s it. I have written a higher level buffer free function so that the mutex code only appears in one place.
There is an issue in this code to do with initialising the pool but I don’t want to complicate things yet.
