Author Topic: Reference design for Padauk MCUs  (Read 1436 times)
Offline notanickTopic starter
  • Country: pt
« on: January 04, 2019, 01:29:19 pm »
There's a great discussion going on reverse engineering the programmer for Padauk's microcontrollers. The folks there are making a very impressive progress and I do not wish to interfere in that discussion. So, I'm posting this question separetely.
I'm intrigued by the flash products, more specifically, the PFS154 and the PFS173.
Does anyone have a schematic for these two in particular or any other of Padauk's MCUs? For the life of me, I'm unable to find anything and I'd like to see how others have sized the power supply bypass caps, protected the power input (which needs to go up to 8V for programming), shared the programming pins with other peripherals, und so weiter.
Offline spth
Re: Reference design for Padauk MCUs
« Reply #1 on: April 23, 2019, 08:33:26 pm »
I've made a board that supports the PFS154 and the PFS173:
https://github.com/free-pdk/f-eval-boards
I've run some C programs (written in C) on them, in particular the LED timer count example (https://github.com/free-pdk/sdcc-pdk-code-examples).
Offline ali_asadzadeh
« Reply #2 on: April 24, 2019, 05:08:59 am »
Thanks for sharing, I'm a windows and Altium user, would you please add PDF files to your repo? :)
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
