Author Topic: Dead Launchpad FET  (Read 2844 times)
Offline alexwhittemoreTopic starter
Dead Launchpad FET
« on: February 16, 2012, 06:34:56 pm »
I ran into what I'm pretty certain is a hardware issue with my Launchpad board today. I've used it successfully before, but CCS started complaining about no USB FET present. Comparing with my same chip and a friend's board, it looks like the flash emulation portion of the board just up and kicked the bucket on me. Maybe I shocked it or something without knowing.
Anyway, has anyone had a similar issue? Anyone know if there's a way to reset the FET portion? For $4.30 it's almost certainly not worth my time, but hey, I hate to waste a good board.
Offline vtl
Re: Dead Launchpad FET
« Reply #1 on: February 17, 2012, 01:57:15 am »
Does the device show up in device manager? (I assume you're using Windows). If so you might try flashing the firmware
http://processors.wiki.ti.com/index.php/MSP430_LaunchPad_Firmware_Update
I must say these boards are pretty resilient though, I've accidentally short circuited VDD to VSS many times and the internal protection on the board works a treat.
« Reply #2 on: February 17, 2012, 09:42:35 pm »
I mean, shorting VDD and GND should be the last thing that *Bricks* a device :P. If you haven't considered that contingency, you're just not trying.
But anyway, no, the device fails to install automatically in a new machine, then doesn't show in device manager, hence my suspicion it's beyond repair. But I'll have a look at the link when I get a chance, thanks!
