Digits test. Probably could be simplified, but it lets you see the mechanics very easily.
#include <stdbool.h>
#include <stdint.h>
#define char_count 4
#define seg_count 8
#define A 1
#define B 2
#define C 4
#define D 8
#define E 16
#define F 32
#define G 64
const uint8_t digits[] = {
(A+B+C+D+E+F), //0
(B+C), //1
(A+B+G+E+D), //2
(A+B+C+D+G), //3
(F+G+B+C), //4
(A+F+G+C+D), //5
(A+F+E+D+C+G), //6
(A+B+C), //7
(A+B+C+D+E+F+G), //8
(D+C+B+A+F+G), //9
typedef enum {
seg_a = 0,
seg_b,
seg_c,
seg_d,
seg_e,
seg_f,
seg_g,
seg_dp,
} seg_name_t;
typedef enum {
char_1 = 0,
char_2,
char_3,
char_4,
} char_name_t;
typedef struct{
const uint8_t reg;
const uint8_t mask;
} seg_data_t;
seg_data_t seg_data[char_count][seg_count] = {
[char_1] = {
[seg_a] = { LCD_RAM_REGISTER0, 1 },
[seg_b] = { LCD_RAM_REGISTER0, 5 },
[seg_c] = { LCD_RAM_REGISTER4, 5 },
[seg_d] = { LCD_RAM_REGISTER6, 1 },
[seg_e] = { LCD_RAM_REGISTER4, 1 },
[seg_f] = { LCD_RAM_REGISTER2, 1 },
[seg_g] = { LCD_RAM_REGISTER2, 5 },
[char_2] = {
[seg_a] = { LCD_RAM_REGISTER0, 6 },
[seg_b] = { LCD_RAM_REGISTER0, 10 },
[seg_c] = { LCD_RAM_REGISTER4, 10 },
[seg_d] = { LCD_RAM_REGISTER6, 6 },
[seg_e] = { LCD_RAM_REGISTER4, 6 },
[seg_f] = { LCD_RAM_REGISTER2, 6 },
[seg_g] = { LCD_RAM_REGISTER2, 10 },
[seg_dp] = { LCD_RAM_REGISTER6, 10 },
[char_3] = {
[seg_a] = { LCD_RAM_REGISTER0, 11 },
[seg_b] = { LCD_RAM_REGISTER0, 12 },
[seg_c] = { LCD_RAM_REGISTER4, 12 },
[seg_d] = { LCD_RAM_REGISTER6, 11 },
[seg_e] = { LCD_RAM_REGISTER4, 11 },
[seg_f] = { LCD_RAM_REGISTER2, 11 },
[seg_g] = { LCD_RAM_REGISTER2, 12 },
[seg_dp] = { LCD_RAM_REGISTER6, 12 },
[char_4] = {
[seg_a] = { LCD_RAM_REGISTER0, 13 },
[seg_b] = { LCD_RAM_REGISTER0, 14 },
[seg_c] = { LCD_RAM_REGISTER4, 14 },
[seg_d] = { LCD_RAM_REGISTER6, 13 },
[seg_e] = { LCD_RAM_REGISTER4, 13 },
[seg_f] = { LCD_RAM_REGISTER2, 13 },
[seg_g] = { LCD_RAM_REGISTER2, 14 },
void clear_char(char_name_t c){
uint16_t mask;
for(uint8_t i=0; i<seg_count; i++){
mask = 1 << seg_data[c][i].mask;
HAL_LCD_Write(&hlcd, seg_data[c][i].reg, mask, 0 );
HAL_LCD_UpdateDisplayRequest(&hlcd);
// Dp not implemented
void write_char(char_name_t c, uint8_t number, bool dp){
uint16_t mask;
if (number>9)
number=8;
( ((1<<i) & digits[number]) ? mask : 0 ) );
void main(void){
uint8_t a=0, b=0, c=0, d=0;
while(1){
write_char(char_1, a, false);
write_char(char_2, b, false);
write_char(char_3, c, false);
write_char(char_4, d, false);
if(++a>9){
a=0;
if(++b>9){
b=0;
if(++c>9){
c=0;
if(++d>9)
d=0;
HAL_Delay(1000);
