Author Topic: ESP8266-12F (Trouble Getting Started)  (Read 2136 times)
Offline metrologist
Re: ESP8266-12F (Trouble Getting Started)
« Reply #25 on: April 28, 2018, 03:49:03 am »
Thanks, I came across that eventually.
And the persistent error messages I receive. It does not stay running long. Many had the same problem and there seemed to be dozens of different things people did to "fix" the problem, from code, wiring, board settings, other code bits such as ignore interrupts and some others...
Fatal exception
panic
and rst messages that I posted above - are like ants.  :scared:
