My SAMD21 will possibly face some EM noise (motor some distance away and a spinning magnet a few millimeters from the chip), so I was looking at the datasheet wondering which protection measures I need to implement.
Power supply connections: my power is coming from a buck converter placed close to the chip, so I would like to know which decoupling capacitors I should use (Section 42, page 1152 of SAMD21 datasheet). Specifically, there is no GNDANA pin on the SAMD21E I'm using, or VDDIO, so clearly I can't place capacitors there. Is a decoupling capacitor on VDDIN still needed given the buck output is very close?
Reset RC filter: is that really needed? When the chip will be programmed, the motor will be off and the normally spinning magnet stationary, so I don't envision much noise at that time. Should I still implement the RC filter on the reset pin?
Thanks in advance.
