Author Topic: Segger J-Link  (Read 2500 times)
Offline bingo600
Re: Segger J-Link
« Reply #25 on: April 02, 2025, 01:38:40 pm »
Cube IDE does not run with the debugger either. When I do F11 (build and load FLASH) even with a ST chip it says "failure to execute MI command". With the GD407 it doesn't find an ST device which is probably not surprising.
david_alpha has "beaten" Cube IDE into submisiion for Pyua (Non ST) , in the Puya thread.
Online peter-h
Re: Segger J-Link
« Reply #26 on: April 02, 2025, 01:56:03 pm »
Right, but he is an expert :)
I have no real need to run Cube with the Segger box. I just got the (fake) Segger to load code into the GD 407, which it does do, using J-Link.
