Author Topic: Simulation software for raspberry pi  (Read 13986 times)
Offline brainwash
    • Hack Correlation
Re: Simulation software for raspberry pi
« Reply #25 on: November 05, 2017, 05:16:57 pm »
Which language? What OS (assume Windows)?
I was using window 10.  I work only with c programming. I found that I can do it with php or asp.net. I  find so much for serial port program. But I could not get success. finally I left because learning many language was very difficult for me
Python is probably easier to learn than C, just follow some examples online: https://playground.arduino.cc/Interfacing/Python
If you know Python you are probably well-equipped to do IoT stuff on the rPI.
You should also research what kind of sensors you want to interface with. Depending on their protocol/wiring you might not be able to interface with them directly from the Raspberry and still need to use another component (Arduino-like) to get data.
Offline ParthTopic starter
  • Country: in
« Reply #26 on: November 12, 2017, 09:58:53 am »
Hi All
Today I am very happy,  got my RPI board. I have attached picture of my board. May be within three day's I will have Micro SD card and ethernet cable
any suggestion to utilize  the time
