Author Topic: Smaller Alternative to 328P  (Read 2435 times)
Offline paul_g_787Topic starter
« on: October 30, 2019, 12:25:03 am »
Hi.
I have a project that I created on an Arduino Uno which uses the 28-pin ATMega 328P-PU DIP. However I am only using a few of the pins on the 328P and was wondering if there is an alternative micro-controller which is compatible with the Arduino IDE that I can use in place of the 328P-PU?
I already know about the ATTiny 45 and 85 but these are too small as they are only 8-pin! I require a minimum of 4 digital GPIO pins and 3 Analogue GPIO pins.
Physical size is important in this project, I need to get the device as small as possible, but still using a DIP IC.
Is anyone able to recommend anything or point me in the right direction at all?
Offline jhpadjustable
  • Salt 'n' pepper beard
Re: Smaller Alternative to 328P
« Reply #1 on: October 30, 2019, 01:35:05 am »
A quick google implies that the ATtiny84 has a support package. Will that do? https://github.com/damellis/attiny
"There are more things in heaven and earth, Arduino, than are dreamt of in your philosophy."
Offline Mr. Scram
  • Display aficionado
« Reply #2 on: October 30, 2019, 01:46:29 am »
Using an SMD part is the obvious solution but you say you need DIP. If size really matters I'd look into eliminating the DIP part. Or could you maybe multiplex or eliminate one or more outputs?
Offline Brutte
« Reply #3 on: October 30, 2019, 09:16:04 am »
This is the tool you need.
The following users thanked this post: artag
Offline Psi
« Reply #4 on: October 30, 2019, 09:28:20 am »
ATTiny26 comes in 20pin DIP and has ADC, a lot of the ATTiny's dont have the ADC
ATTiny44 comes in 14pin DIP and has ADC too.
« Last Edit: October 30, 2019, 09:32:04 am by Psi »
« Reply #5 on: October 30, 2019, 08:35:21 pm »
« Reply #6 on: October 30, 2019, 08:45:56 pm »
Thanks for that. just has a look at the ATTiny 44 and also found the ATTiny24 which is cheaper.
If I were to use the ATTiny24 would I require an external crystal or can it be done without like with the 328P?
Offline sleemanj
  • Professional tightwad.
« Reply #7 on: October 30, 2019, 09:06:05 pm »
Gah, do not use damellis' package, it is worse than useless.
Better arduino cores to support the various tinys:
https://github.com/sleemanj/optiboot/blob/master/dists/README.md (my own highly optimised for space supporting the 24/44/84, 25/45/85, 13, 4, 5, 9 and 10)
https://github.com/SpenceKonde/ATTinyCore/ (that from which mine derives, not so optimised for space and doesn't handle the 13 and smaller)
https://github.com/SpenceKonde/megaTinyCore (for the new generation of attinys)
The following users thanked this post: jhpadjustable
Offline sleemanj
« Reply #8 on: October 30, 2019, 09:07:38 pm »
Internal oscillator is fine.
Offline jackthomson41
« Reply #9 on: October 31, 2019, 01:31:13 am »
Hi.
I have a project that I created on an Arduino Uno which uses the 28-pin ATMega328 P-PU DIP. However I am only using a few of the pins on the 328P and was wondering if there is an alternative microcontroller which is compatible with the Arduino IDE that I can use in place of the 328P-PU?
You can use ATtiny44 or ATtiny85, both will do the job and will fulfill your requirements.
« Last Edit: April 18, 2020, 02:34:01 am by jackthomson41 »
Offline Psi
« Reply #10 on: October 31, 2019, 08:16:08 am »
Make sure you check how much flash memory and RAM you will need.
Have a look how big your current 328P project is compiling down to.
The smaller ATTinys don't have much flash or SRAM. The arduino libraries do add some annoying overhead.
The ATTiny24 only has 2K flash and 128bytes SRAM which is not much.
I would look at 4K of flash unless your sure 2K will be enough. I tend to go for the 8K ones myself, just because i don't want to deal with out of mem issues.
The Arduino bootloader takes like 512 Bytes of flash. so on 2k you've lost 1/4 already, without any code at all.
I think many people program the ATTiny's without the serial bootloader to save space.
« Last Edit: October 31, 2019, 08:24:21 am by Psi »
