Author Topic: ATF1500/ATF2500  (Read 4480 times)
Offline JokTopic starter
ATF1500/ATF2500
« on: June 09, 2015, 08:33:57 am »
anyone know about a cheap programmer that will happily take ATF1500 and ATF2500 DIP series Atmel CPLD's?
The only ones I've looked at so far are in the range of 500-1000 USD and that seems a little steep for a few one off tests.
Regards
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
Re: ATF1500/ATF2500
« Reply #1 on: June 11, 2015, 12:28:57 am »
The ATF1500 and ATF2500 were programmed with a proprietary algorithm that Atmel has never publicly released. Only a few programmers support them, and they are expensive because they were designed to work with many different device types. You might be able to make a compatible programmer using the information found at http://matthieu.benoit.free.fr/120.htm, but it's probably not worth the effort.
Later versions of the ATF15xx series use jtag protocol, so they can be programmed with an Altera Byte Blaster or equivalent. Some of these chips are still available, though not in DIP packages. You could put them on PLCC or TQFP to DIP adapter boards for 'one-off' testing.
