Author Topic: stm32f103-Can't trigger IRQ9_5 interrupt?  (Read 1175 times)
Offline kgavionicsTopic starter
« on: April 20, 2022, 05:15:00 pm »
Hello, I'm a new to the STM32 programming. I'm coming from the AVR ! So don't be too hard on me  ;D ;D
I'm trying to trigger an interrupt using the below  code, but I can't trigger the interrupt. When I press on the switch, nothing happens. I don't know what I'm doing wrong. Can someone help me please?
#include <stm32f10x.h>
// PA6 connected to an external pull-up resitor and a momentary switch
void EXTI9_5_IRQHandler()
EXTI->PR |=(1<<6); // Clear pending interrupt
GPIOA->ODR ^=(1<<7);// Toggle a led connected to PA7
int main()
RCC->APB2ENR |= (1<<0) | (1<<2); //enable GPIOA and AFIO cloks
  GPIOA->CRL =0x34444444; //P7 output, the rest are inputs
AFIO->EXTICR[1]=0;// EXTI6 (BITS 8-9-10-11 are 0000)
EXTI->FTSR |=(1<<6);// Falling edge
EXTI->EMR |=(1<<6); // unmasked intp6
NVIC_EnableIRQ(EXTI9_5_IRQn);
while(1);
Offline hans
Re: stm32f103-Can't trigger IRQ9_5 interrupt?
« Reply #1 on: April 20, 2022, 05:23:38 pm »
You could try to use IMR instead of EMR of the EXTI registers.
Event and interrupts are separate in STM32 (and more ARM CPUs, but not all): interrupts trigger a software interrupt vector, while an event is typically used between peripherals as triggers (e.g. for DMA, timer updates, or other peripheral 'events')
« Last Edit: April 20, 2022, 05:25:32 pm by hans »
The following users thanked this post: kgavionics
« Reply #2 on: April 20, 2022, 05:35:18 pm »
Thank you very much Hans, by changing EMR to IMR,  my code worked right away!
Thanks again, you really made my day!
Offline DavidAlfa
« Reply #3 on: April 22, 2022, 04:47:36 am »
Was going to say that.
Doesn't ARMs need to configure the nvic, setting the jump locations?
He's doing it bare-metal so he will have to take care of every single bit.
« Reply #4 on: April 23, 2022, 12:57:33 am »
My code above,is taking care of everything.the only mistake I made is that I used EMR instead of IMR register.
